View Full Version : Standard brazing rod
Black_Moons
03-17-2012, 03:19 AM
Ok, So what exactly is the hardware store brazing rod? As in, what alloy should I expect it to be? the brass type, Not the nickle rods.
PTSideshow
03-17-2012, 06:13 AM
It is a low fuming, bronze alloy copper,zinc and a little phosphorus. Of course your mileage may vary, due to the alloy and what company has made it and rebranded it.
The other common yellow type torch rods are naval bronzes, silicon bronzes. They than get more into custom blends
Crown alloy's general purpose brazing alloy for torch is Crown 125 bare, if FC after it is flux coated. Tensile strength is up to 65,000 psi working temp is 1670°F to1750°F Flux is used.
ptjw7uk
03-17-2012, 06:30 AM
Have a look at this pdf - Harris
http://www.harrisproductsgroup.com/~/media/Files/PDF/Requested%20Resources/GuidetoBrazingandSoldering.ashx
Have a few alloys listed near the bottom!
Peter
Here, unless you go for something specific, either manganese bronze or tobin bronze.
