View Full Version : File metal flush
goeb8
03-19-2012, 03:02 PM
I have cut the nut but there is little bit left over. I have many types of battery powered tools but not a grinder. There is no access to an electrical outlet. Any advice on removing the left over metal so I can separate the 2 pipes. If using a rotary tool, is there some kind of bit that can do the job. I am trying to avoid manual filing.
http://i384.photobucket.com/albums/oo283/joew87/pipes/0311021600b.jpg
JCHannum
03-19-2012, 03:35 PM
Why??????????
flathead4
03-19-2012, 03:43 PM
How about a chisel? If you don't have a chisel, you can make one with a file.
goeb8
03-19-2012, 05:16 PM
the range is limited. using a filer, filing back & forward will hit the floor that will lose momentum. tables would be a good idea but i don't have access to 2 tables and clamps because pushing force on the metal surface while filing is needed.
Why??????????
goeb8
03-19-2012, 05:18 PM
but there is a bit of the nut left. i assume that little piece of the nut holding on to the shaft of the bolt.
Patch
03-19-2012, 05:45 PM
http://www.buydrillbits.com/products/burrs.php?gclid=CK7HrJb2864CFcMbQgodCU83MA
Home Depot, Ace Hardware, Amazon.com, perhaps the site listed?
Insert to drill, grind away.
oldtiffie
03-19-2012, 06:06 PM
I presume that by "nut" you mean bolt or screw.
Why not centre punch it and drill it out with one of your battery-powered drills?
rohart
03-19-2012, 06:34 PM
If you drill to just a shallow depth with a bit almost the full diameter of the bolt shank, then you can use a small chisel to collapse the edges of the bolt shank inwards. This will shorten the shank and remove the extra bit that is holding the flange in place.
danlb
03-19-2012, 11:15 PM
It's just like drilling out a rivet. Pick a drill the same size as the shaft, maybe a touch bigger. Center punch it first. The drill will slice the edges of the bolt/nut right off. If your drill takes a small nip out of the flange it's no big deal.
Dan
Uncle O
03-20-2012, 03:25 AM
That appears to me to be a pipe and catalytic convertor .....Yes ?
Just give it a few whacks with a good hammer and it will loosen up the rust that is holding it together.
goeb8
03-20-2012, 02:58 PM
it is a catalytic converter connected to the front pipe. the nut fused so it had to be cut off. the other side is the bolt. thank you for everyone's reply.
hey Patch, i have never used a Carbide Burrs bit before. a long list of Carbide Burrs bits. which one do you suggest that can do the job?
Tony
03-20-2012, 03:16 PM
hahaha... oh man. now I have to clean coffee off my screen.
