3t-
03-29-2012, 08:32 AM
On the BP J heads and J head clones the power quill feed has a kick out that stops downward travel when the depth stop is contacted. Since the power quill feed can also be reversed via the directional knob being either pushed in or pulled out (depending on the rotation of the spindle at the time) and the quill power fed back UP. What is the danger to the gearing if the quill is allowed to reach it's upper limit of travel, under power feed, since there is no "kick out" for this direction? (other than moving the feed engagement handle by hand)
Or am I missing something and there is a disengagement mechanism built in for the upward power feed?
Thanks
Thanks
