View Full Version : Is this normal?
customcutter
04-24-2012, 10:11 PM
I have a new/used Birmingham CT1440G (mfg 2001). No manual or wiring diagram.
I think I've figured out most of the problems, between wiring it for 220v when it was wired 110V, and a sticking switch on the spindle control lever.
I release the E-stop button, turn on the power switch, and push the start button. If the spindle control lever is in neutral it will start the spindle for about 3-5 seconds and then stop the spindle. Should this be happening???
If the spindle control lever is not in neutral when I turn on the power switch nothing happens. This is a safety feature I'm sure.
thanks,
Ken
