View Full Version : Toroid Transformers
ironmonger
04-25-2012, 02:44 PM
Does any one have a source or lead on toroidal transformers. I am seeking two units around 1000VA each to build a pair of DC servo supplies. Need secondaries to get to about 70 and 100 VAC.
E core stuff is OK as well, just harder to modify than toroids, and I certainly would look at a good surplus source for linear supplies. I can but these new for under $200 it seems, but I remain eternally cheap and hopeful...
Never hurts to ask
Thanks
paul
MaxHeadRoom
04-25-2012, 02:47 PM
There is a guy who build them, I believe custom also, although if you get one close it is easy to wind on or take off a few turns.
Antek or his ebay name is jonango.
http://www.antekinc.com/
Max.
macona
04-25-2012, 04:00 PM
I have a big transformer from my old mill. Probably good for at least 2kw. 70v out.
ironmonger
04-27-2012, 10:10 AM
Hi Macona
I tried a PM. I would be interested in the transformer.
If you run two servos from one PSU is it sufficient to run two separate banks of filter caps?
Does it help to add a diode to each supply?
thanks
paul
MaxHeadRoom
04-27-2012, 10:14 AM
If there is only one secondary then generally 1 appropriately sized bridge and 1 capacitor bank is used?
If you need to add a small overwind for 5v - 24v supply, the turns ratio is around 2t/volt.
Max.
macona
04-27-2012, 07:48 PM
Ahh, forgot to reply.
This transformer ran 3 good sized servos.
