View Full Version : Question for the cast of CSI Electronics®
DICKEYBIRD
05-14-2012, 09:02 PM
After my embarrassing gaffe with the contactor coil/ammeter yesterday I figured what the heck, I'm on a roll...ask more questions.
I won a Tamura 24VDC 2.4A power supply on ebay. It arrived today and I was surprised at the size & weight. The thing is almost 6 inches square and weighs 4 1/2 lbs! Why does it need the huge transformer? Why all the other electronics? I recognize the bridge rectifier & the big capacitor but what's with all the other electronics....and the power transistor on the bottom? Please reduce my ignance and educate me; the Cliff Notes version.:)
ps: Not everyone makes a killing on ebay. No other bids and it sold for $5 plus $10.15 shipping. The postage sticker on the box read $16.95.:eek: The fellow definitely gets positive feedback.
http://i57.photobucket.com/albums/g227/DBAviation/Tamura24vdc.jpg
http://i57.photobucket.com/albums/g227/DBAviation/TamuraTransistor.jpg
MaxHeadRoom
05-14-2012, 09:11 PM
Its a linear supply, but regulated, much heavier than switching supplies, they often have a crowbar short circuit protection, also you notice there is 2 terminals for each output, if you have a long run to feed the load, you use 4 terminals instead of two and take a pair to the load to sense the voltage drop and the output will increase accordingly.
The 2SD797 is the series regulator transistor.
Max.
DICKEYBIRD
05-14-2012, 09:18 PM
Thanks Max, enlightening as always.:)
rdfeil
05-14-2012, 09:24 PM
Milton,
The transformer is typical of that in a linear power supply. Linear meaning that everything happens at line frequency, 60 hertz. At low frequencies you need more iron than at high frequencies. That is why a switching type power supply, like in computers, have much smaller transformers and capacitors as they first simply rectify the line voltage to get high voltage DC then switch that at a much higher frequency, 40,000 to 100,000 hertz, so that the transformers need much less iron to perform properly. The 'extra' electronics is for regulation. Without regulation the voltage will not be stable with varying load currents. Also, that power supply has remote sensing regulation. Notice the two extra terminals next to the output terminals labeled S+ and S-. Those terminals are used to provide remote voltage sensing for the regulator circuitry. For example, say you were to locate the power supply a long distance away from what it is powering. You would have losses in the wiring between the power supply and the load. Now if the load is constant you could simply adjust the power supply to provide the proper voltage to the load, but is the load varies the voltage would have to constantly be adjusted to provide the proper voltage. Enter the remote sense circuitry. To use remote sense you run two extra wires from the power supply to the load, they are normally very small wires as they don't provide power they just measure the voltage at the distant end. Now when you set the power supply for the proper voltage the remote sense will automatically adjust the power supply to keep the voltage at the load constant.
This is a little more than the cliff notes version but I hope it helps.
Edit: Max beat me with the cliff notes version. :D
DICKEYBIRD
05-14-2012, 09:54 PM
Thanks Robin, even I could understand that explanation.
Looks like I got my money's worth; that's a pretty decent piece of equipment. Ya never know when I'll need precisely 24V way across the shop from where the supply is mounted.:)
05-14-2012, 10:19 PM
One added point.....
The supply is really a 30 volt (or thereabouts) 2.4 amp supply..... the "regulation" occurs by holding the OUTPUT constant while the input varies.
Since 24V at 2.4A is about 58 watts, and 30V at 2.4A is 72 W, the transformer has to supply a bit more than 72 watts or so. The difference between that and the output wattage is dissipated in that large power transistor, warming up the chassis/heatsink.
The transistor functions as a "variable resistor" * which is "adjusted by" the electronics to provide the exact needed voltage at whatever current is being drawn at that moment..
Actual numbers may vary depending..... but the idea is the same.
* The very name "transistor" is, IIRC, derived from "transfer resistor", which was a descriptive term used in the very early days of development of the device.
darryl
05-15-2012, 12:30 AM
The regulator ic in there, the 723, is a decent regulator. I've seen those used in power supplies with 20 or more amps of output, and you wouldn't even see the voltmeter budge between no load and full load. The worst problem I see in any adjustable power supply is with the adjustment pot itself. They tend to develop an intermittent, which will throw things out of kilter- enough at times to cause damage in the supply, not to mention whatever load is attached.
That thing in there called VR1- that's the voltage adjustment pot. If you carefully mark the position it's in, then rotate it a bit (power off and stored charges dissipated, or unplugged for the night) you will feel a point where the contact has made a tiny dent in the track. This is the point you want to return the control to when you are done applying contact cleaner and working the control back and forth a bit. You should find the output voltage varying quite smoothly when you turn the control. A cheap analog meter is probably best for this test.
Regardless, this is probably the best preventive maintenance you could give that power supply.
oldhat
05-15-2012, 09:27 AM
Hi all
I have work in electronics for over 40 years, in aerospace for 9 years.
From what I have seen is that a linear power supply last minnie times longer then switching power supply and take power surges better.
Switching power supply from china are no good the caps are under rated for Temperature and power factor and voltage. Go bad in 3 to 4 years if not faster.
Bill
DICKEYBIRD
05-15-2012, 09:35 AM
Welcome Bill!
I have little electronics knowledge but after feeling the weight of the thing, looking at size of the components and the hand soldering, I totally agree with you. This thing is built to last...and to be repaired if needed.
browne92
05-15-2012, 10:35 AM
I think Max is right. It's crowbar protected. The two big precision power resistors off to the left are for that. Darryl: VR1 is marked O.C.P. Over current protection. VR2 is marked V. Adj. That will be your voltage adjust.
Careful how you mount this thing. The large chunk of aluminum is probably grounded. The case of that regulator is probably not. I'm guessing it has unregulated voltage on it.
Another thing you don't see much anymore...transformers with taps for different input voltages.
Nice find.
DICKEYBIRD
05-15-2012, 10:46 AM
Thanks, I bought it to power a contactor coil in an ongoing CNC lathe retrofit thinking I needed 1.46 A. Turns out my ammeter lead hookup was, uhhhh, flawed and I only need .34A.
I'm now using a smaller power supply for the lathe and have stored the Tamura safely away in a padded box for use down the road for some yet unknown project. Perhaps a small CNC device with some of the little stepper motors I've got ratted away around here somewhere...or a mill power feed...or who knows.
Hopefuldave
05-15-2012, 11:58 AM
Nice score - I much prefer linear supplies to switchers, for one thing they don't wipe out radio reception in the Shed Of Danger....
Only downside is the engineers' "rule of toe" - you can work out how many Amps it'll deliver by dropping it on your foot, count the broken toes, that's how many Amps... :D
Dave H. (the other one)
DICKEYBIRD
05-15-2012, 12:43 PM
...you can work out how many Amps it'll deliver by dropping it on your foot, count the broken toes, that's how many Amps... :D That there's funny! (As long as it's somebody else's toes that is.)
OK, nudder edumacation wanted (just sayin'). Now that I have this manly 24V power supply with all that extra oomph available, if I wanted to use it for the contactor coil (only needs to supply 340mA for that) what would be needed for it to supply 12VDC for my cooling fans, the B.O.B. and 5VDC for the other side of the B.O.B. and spindle sensor board?
I have a good PC power supply assigned to do the 5V/12V job already but was curious what type of circuitry would be required to drop the 24V to the lower voltages.
MaxHeadRoom
05-15-2012, 01:02 PM
- you can work out how many Amps it'll deliver by dropping it on your foot, . :D
Yes they used to sell them by the Lb! ;)
I would not go to the bother of using regulators off of that supply.
(LM7805,LM7812, LM317 etc)
When getting into various supplies for common control work, it often pays to look for a Toroidal transformer, get one that suits the main winding you want and then wind on a few turns for the lower supplies, generally 2t/volt.
Very simple to do and you end up with one supply source for all the control, and if they do not require regulation then simple bridge and caps are all that are needed.
General control circuitry for relay, contactors, fans etc, do not require regulated supplies.
Max.
Hopefuldave
05-15-2012, 01:03 PM
Hi Dickey,
For the 12V supply, easy - a "7812" regulator chip will do an Amp, a couple of capacitors and a diode will keep it stable, then from the 12V line a "7805" would be very similar and give 5V at an Amp - to save running both supplies through the same 1-Amp regulator, *some* 7805 's will cope with 24V on the input, so google "78**" datasheet and have a read!
If you want to get fancy and make nice neat PCB's, there are some youtube video tutorials on the "Eagle" PCB software - there's a freeware version you can download that'll do small PCB's from circuit diagram to finished artwork (and even CAM files...), though stripboard would do a good job too!
If you're considering PC power supplies, be aware that the newer ATX supplies need a couple of leads loaded to get the main 5V and 12V supplies to kick in... Same with some of the 5V + 12V "cable wart"/"inline brick" supplies (e.g. Cisco's ickle-router supplies).
DICKEYBIRD
05-15-2012, 01:45 PM
Thanks Max & Dave. I'll take the easy way out & use the stuff I already have but was curious what it'd take to drop the 24V down.
I'd totally forgot about the reg. chips. Long time ago I made a field trickle charger for my r/c airplane rcvr. batts using a Radio Shack regulator to drop 12V down to 5V or so. Still works!
Thanks for all the education!:)
Paul Alciatore
05-15-2012, 02:07 PM
No need for a regulated supply for a contactor coil so you do not need a Voltage regulator to power that. A simple dropping resistor will drop the extra 12 Volts and would be more reliable. You would put that resistor in series with the coil: 24 Volt supply - to - resistor - to - coil. A simple calculation is needed for such a resistor. First Ohms law to get the resistance value: R = E/I or R = 12V/0.340A = 35.3 Ohms. 36 Ohms is the closest standard value and will work just fine. You also need to calculate the power dissipated in that resistor. P = V*I or P = 12V * 0.340A = 4.08 Watts. A 5 Watt resistor would work but I would step up to 8 or 10 Watts for a little headroom which would give longer life. So a single 36 Ohm, 8 or 10 Watt resistor will allow you to operate that coil.
Notice that this calculation is dependent on the actual coil current draw. This means that the 12 Volts you get at the coil is not regulated and you can not add additional devices at that 12 Volt point without changing the 12 Volts to another value. Cheap and dirty: it works, but is not regulated.
browne92
05-15-2012, 03:05 PM
One other thing. I would stand those two power resistors back up. The reason the leads are so long is they will generate some heat at full current draw, so they want to get them off the board. Lets some air get around them, and the board doesn't heat fatigue.
DICKEYBIRD
05-15-2012, 03:34 PM
...and so it shall be Obi Wan.:)
