View Full Version : 01 morse taper question
Alistair Hosie
05-15-2012, 04:34 PM
Where preferably in the uk can you buy a morse taper 01 dead or live centre Fred my old pal asked me to ask you? Alistair
aboard_epsilon
05-15-2012, 05:35 PM
i dont know if they make minature ones
all i know is that they are sizes 0 to 7
second table down
http://www.newmantools.com/tech/taper.htm
number 1 tapers if you mean them are available from arceuro .ebay ..anywhere
bit harder to get a 0 one
hmm..............
maybe he said ..get me a zero one ...or a naught one....meaning he wanted a MT0
all the best.markj
uncle pete
05-15-2012, 06:35 PM
The 01 designation throws me off. But if it is a MT 0 your looking for. I seem to recall that's what the Sherline lathes use.
Pete
Alistair Hosie
05-15-2012, 07:04 PM
Thanks guys I will check tomorrow with him too late tonight I think he meant 0 morse taper but maybe he meant 1 morse taper I think it is 0 though I will be back thanks so far pals. Alistair
sasquatch
05-15-2012, 07:08 PM
Ive seem #o M/T in tool catalogs,, i think just a couple, and yes i think sherline and maybe Taig use them also.
The old Dunlap built lathes (metal and wood), i think also used those tapers.
They're pretty small, think the large end is right around 1/4 inch.
KBC tools carries the morse taper drill sockets in #1 also reducing sleeves, so they must be available somewere around your'e country.
05-16-2012, 12:24 AM
Sherline doesn't use a real MT0, they use a cut-off version with the same taper, but much shorter. it will fit, but for instance, will not eject from a tailstock.
I actually have a single MT0 center left over from an old machine..... sold two others with the machine. No idea where you'd get one, they are not at all common. The mate to it I had to drill out from the spindle, it was wedged in tight.
I do have an MT0 reamer though.
MT1 is pretty common comparatively. lots of small MT drills use that taper, up to 15/32 or so (11.9 mm).
While MT1 centers are not quite as common as drills, I do see them on lists of available tapers. I think small 6" (3" to you, Alistair) Atlas lathes use that in the tailstock.
Arthur.Marks
05-16-2012, 12:38 AM
You're lucky :) for being in the UK on this one. If your friend is in need of true 0 Morse tooling, Cowells Machine (http://www.cowells.com/) has all sorts of items (http://www.cowells.com/acc_90e.htm). Their 90ME lathe has a tailstock taper of 0 Morse.
oldtiffie
05-16-2012, 02:15 AM
MT details:
http://i200.photobucket.com/albums/aa294/oldtiffie/machine_tapers/Machine-taper2.jpg
aboard_epsilon
05-16-2012, 07:44 AM
had a look at that site the other day , 2049.00 for what looks like a cheap chinese mini mill .. 135 each for a collet....what are they on. !!!
Arthur.Marks
05-16-2012, 08:59 AM
:confused: ...making a very quality machine entirely in the UK that is precise, accurate and guaranteed to be so? Those "collets" are Schaublin B8. Nothing to skoff at. In comparison to similar watchmakers' equipment, I consider them rather affordable. I don't have much to say, though, about the mill. I've always been more impressed with the lathes.
