View Full Version : Quick and dirty 4-jaw set-up
ZINOM
05-25-2012, 03:35 PM
Hey all,
I don't do much work with the 4-jaw chuck so any kind of "cheat" helps me.
I use a little jig to hold a stack of fiber washers while drilling the hole out from 1/4" to 3/8". It works (worked) great until I ran out of the large quantity of washers I'd been using finally, and started on a new batch.
The new ones are a few thou bigger than the old ones so I decided to enlarge the hole in the jig. I used a steel ball bearing that I've had hanging around for years and seated it in the hole while being held in place by the tailstock chuck. I brought the jaws into position while rotating it to make sure I was staying in contact with the tailstock chuck and....ta-daaa.
I'm sure it's old news or common sense for most, but for me, this Q&D method saved me some time and probable frustration so maybe it'll help someone else.
Thanks for looking!
John
http://i302.photobucket.com/albums/nn81/ZINOMJOHN/IMG_1486.jpg
http://i302.photobucket.com/albums/nn81/ZINOMJOHN/IMG_1487.jpg
http://i302.photobucket.com/albums/nn81/ZINOMJOHN/IMG_1488.jpg
jcon
05-25-2012, 03:54 PM
Good thinking, if quick and derty works do it.
jcon
Lew Hartswick
05-25-2012, 04:17 PM
In stead of the 3 jaw chuck, a center with a hollow cone (I forget what
those are called) would be even easier and maybe more accurate.
That is very good if there is already a hole in the work.
...Lew...
ZINOM
05-26-2012, 09:52 AM
Thanks guys...that's a good thought Lew.
John
