View Full Version : id cutters please
aboard_epsilon
05-31-2012, 10:56 AM
can anyone id these cutters ..found them in the bottom of a wooden box at a car boot sale today
the ones that are complete have sort of micrometer dials on them
http://img.photobucket.com/albums/v190/aboard_epsilon/id3.jpg
http://img.photobucket.com/albums/v190/aboard_epsilon/ident2.jpg
http://img.photobucket.com/albums/v190/aboard_epsilon/idthese1.jpg
all the best.markj
aboard_epsilon
05-31-2012, 10:59 AM
also found these spanners ..
they are handy too keep around the machines ..they wont wonder off to be used for anything else.
http://img.photobucket.com/albums/v190/aboard_epsilon/spanners.jpg
and shown here ...,are half the quantity of inserts i found in the same box.
they dont look it ..but they are unused
http://img.photobucket.com/albums/v190/aboard_epsilon/inserts1.jpg
all the best...markj
TGTool
05-31-2012, 11:13 AM
The cutters in the first picture are DeVlieg microbore inserts. Used in a boring bar they give you fine adjustment control. There are two different dials though the threads are all the same. One assumes the insert is at right angles to the centerline and the other assumes an angle. Can't remember the angle exactly but they change the number of graduations, making it an even number, and then calculate the appropriate angle so it's a little bit odd.
You can still get them, along with replacement dials, screws, etc. and different end shapes depending on the intended task.
I've seen specialized boring bars manufactured to turn multiple diameters simultaneously, presumably for production jobs.
aboard_epsilon
05-31-2012, 11:33 AM
will have to keep an eye open for the heads to go with them then ..
that's if they come in 30 taper.
anyway ..thanks i went to the site ..looked them up and they are exactly what you say they are .
all the best.markj
Jaakko Fagerlund
05-31-2012, 02:58 PM
Second row from bottom in your insert pics are KNUX inserts, left handed and right handed inserts. Great ones for really removing material and still widely available, though I prefer something else.
lane
05-31-2012, 06:16 PM
You can make your own heads they just screw in at 45. I have made a few. And still have one in my kit.
38_Cal
05-31-2012, 06:43 PM
Well, you're not claiming a gloat or telling us how much you paid, but those cutters are neat enough that I've got to say it...YOU SUCK!
David
aboard_epsilon
05-31-2012, 08:45 PM
3
and not all is in the pictures
i had several tool post box spanners as well out of that box
and a few bits of hss and some grooving /parting tools you can just see in one picture
all the best.markj
frankie
05-31-2012, 11:30 PM
I used that type of cutter in boring bars at my first machine shop job in 1972 they were used in a NC Burgmaster to make truck axles. Yes I did mean to type NC and yes I am that old.
john
NzOldun
06-01-2012, 01:37 AM
john
I can beat that one. I used them, or something very similar, circa 1958:)
Euph0ny
06-01-2012, 09:57 AM
TGTool was clearly too modest to post this link to a most informative thread about those micrometer boring insters:
http://bbs.homeshopmachinist.net/showthread.php?t=41665
