View Full Version : Convert 3ph surface grinder to single
SteveC
03-01-2004, 01:54 AM
Has anyone had any luck converting a 3 phase surface grinder to single phase? I have been looking for a single phase grinder for a long time with no luck. Since the 3 phase grinders are so plentiful, I'm considering changing out the motor. Is this more practical if it is belt driven? Any tips would be appreciated.
Thanks,
Rustybolt
03-01-2004, 02:18 AM
Steve. I tried to that once to a Boyer Schultz 6-12. Their motors use a proprietary mount and are balanced. I don't know about yours, but it would have cost me more than the grinder is worth.
Have you thought about a rotary phase converter?
splicer
03-01-2004, 08:57 AM
Steve:
If your grinder has a dual voltage 220/440volt motor, and you have 240 single phase available, a static convertor will work very nicely.
I have a Boyar Schultz that I run on a home-made static convertor and the no-load spindle speed is actually 150 rpm higher than the rated motor speed.
Hope this helps.
moldmonkey
03-01-2004, 10:27 PM
I'll echo the static convertor. I run a Boyar-Schultz 6x12 on a static and I have been real happy with it.
Jon
SteveC
03-02-2004, 01:05 AM
Thanks for the ideas guys. I don't have a grinder yet, so all my options are open.
I take it that if I did rig a single phase motor on a grinder that the balancing thing would be tuff to accomplish?
DR
03-02-2004, 02:09 AM
Yeah, the balancing would have to be done professionally.
About 95% of the time when people switch to single phase motors they drastically reduce the resale value of their machines.
Get a phase converter or search for that rare single phase grinder.
