darryl
06-16-2012, 09:36 PM
I'm thinking of adding an electric actuator to my bike to deploy the service stand. For some reason I've lost the kickstand, but I'm not too fond of them anyway. Maybe that's why I 'lost' it- I don't know. At any rate, it's getting more difficult to use the service stand. The way my back has been lately it's getting to be a bit of a strain to drag the bike backwards and upwards to deploy the stand. I can still do it fairly easily, but I'm really starting to look for ways to minimize the potential damage I could do to myself.
I've checked out the mechanicals of it, and all I need is to extend an actuator by about three inches. Within that range I have both full deployment and full retraction with some upward pressure left so it isn't left loose at all. There is room for a motorized gearbox if that isn't too large, and the entire thing has to be 9 inches long or shorter between mounting points.
Since it's a 12v system, I'm thinking that I could find some kind of actuator that would work here. I could make up a hydraulic cylinder to fit, then power it from a small pump mounted in the frame somewhere, or it could be a completely self-contained screw jack. My thought was that maybe there is already an electric screw jack made for small cars, etc. Anybody know of such a thing?
I'm guessing that I'm going to need about 300 lbs of force to actuate the stand, given the geometry involved. That should be enough to push the stand all the way over while lifting the rear of the bike off the ground.
I've decided to go ahead with the cargo container retrofit, so there's likely to be a load on the back when I'm out on the road for a few days or more. One of the other options I've considered is having a pair of deployable feet that would simply extend downwards to act as stabilizer feet when I'm parked. I do like the idea of having these feet as far apart as possible for the best in stability. Often enough, when I'm out on the road, stopping in parks and overnight areas, there's kids around that want to sit on the bike. I guess I can understand why, and I don't mind giving them the chance (parents often want to take pictures of their kids sitting on a bike), but it would also be easier on my mind if the bike had a wider stance when parked. With the cargo container fitted, it would essentially be about 30 inches wide, so this is something I could incorporate right into the structure. The feet on the current stand are only about 8 or 9 inches apart.
To incorporate deployable struts mounted inside the cargo container, I'd have to make sure I had mounting points arranged to take the load without stressing the container or the points where it mounts. That's just another detail though, something that can be designed in.
Thoughts?
Thoughts?
