View Full Version : Change gear ID?
donf
07-01-2012, 05:00 PM
I bought my Boxford lathe from a guy who bought it at an auction and some of the change gears don't appear to be for a Boxford. Its ok as Boxford gears seem to be pretty common and the majority are correct.
These three are clearly much bigger though with a width of about 0.625 inches and bore of 0.80 inches. Anyone have a clue as to what they fit?
http://i228.photobucket.com/albums/ee288/earlysb1/for%20sale/1323ce43.jpg
oldtiffie
07-01-2012, 10:14 PM
0.625" is 15.875mm - say 16mm
0.80" = 20.32mm - say 20mm
The gears could be metric - MOD1 - where the OD of the 55 tooth centre gear would be 55 + 2 = 57mm
If that is the case, the pressure angle would probably be 20 degrees
For an "inch" gear the pitch circle diameter is Number of teeth/Pitch Diameter and as 55mm = 2.165" assume 2" in which case DP = 55/2= 27.5
I'd have expected a whole number for the DP but "1/2 numbers" are in use as well.
Its a wild-ar$ed guess but at least its a start.
Having the OD would help.
donf
07-01-2012, 10:24 PM
Thank you for the guess. :) The OD of the 55 tooth is 91.80mm/3.615". The 64 tooth in just over 4"/102.85mm. The 56 tooth is almost the same size as the 55 tooth gear. What ever machine they came off of, these gears are big!
oldtiffie
07-01-2012, 10:51 PM
Thanks for the extra info - appreciated.
I was way out.
For the 64 tooth gear where as a first guess the PCD is 4 ":
DP = 64/4 = 16
OD = (no. teeth + 2)/Pitch circle diam (PCD) = 4.125"
As the gear theOP has has a diameter of 4.05" (102.85mm) and the difference is 4.125 - 4.05 = 0.075" I'd pretty much settle for the gear being 16DP.
I will check again for metric later.
donf
07-01-2012, 11:35 PM
Thank you for the help! I think the gears are 16 dp as they all seem to average very close to that. I remeasured the bore, it is closest to 13/16" but it will be a snug fit.
oldtiffie
07-02-2012, 06:39 AM
I re-did the 64 tooth gear in metric and assumed the pitch circle diameter to be 100mm and the gear to be MOD 1.5
But PCD = 64 x 1.5 = 96 and OD = 96 + (2 x 1.50) = 96 + 3 = 96mm
That is too far below the actual PCD of 102.85mm - so disregard modular gearing.
I would just about bet that the pressure angle is 20 degrees.
oldtiffie
07-02-2012, 08:55 PM
I re-did the calculations again as I made an error as regards the addendum - it is fixed now.
DP = 64/4 = 16
Addendum = 1/DP = 1/64
OD = PCD + (2 x addendum) = 4 + (2 x 1/64) = 4 + 2/64 = 4.031"
As the gear the OP has has a diameter of 4.05" (102.85mm) and the difference is 4.05 - 4.03 = 0.02" I'd pretty much settle for the gear being 16DP.
donf
07-03-2012, 08:54 AM
OK thank you for the help. :)
