View Full Version : Wheel stud material
dp
07-04-2012, 05:41 PM
Anyone know what a good material is for a wheel stud? This is for a small trailer for a motorcycle fwiw.
JCD
07-04-2012, 05:44 PM
You might try: 4130 or 4140
07-04-2012, 05:53 PM
1090,1095,4140,8620.
Did you get a Thread rolling head your not telling us about:D ?
dp
07-04-2012, 06:03 PM
A friend needs a replacement and can't find one. I'm entertaining the idea of making one but it needs to pass the "this is a stupid idea" test, first :)
GKman
07-04-2012, 07:41 PM
I just bought one for a Dodge van after a tire store ruined one somehow. A universal from a parts store wasn't available It was over $.12.00 from Chrysler so I'm thinking they must be made from platinum.
Duffy
07-04-2012, 07:45 PM
How about machining a stud from a grade 8 bolt. I suspect that common or garden variety studs on cars are not any stronger than a grade 8 bolt, With luck you might even get one end already threaded!:D
cuemaker
07-04-2012, 08:22 PM
Try Dorman...you find Dormans part number..you can order from Autozone, Advance Auto etc...they supply studs to an SAE Gr. 8 standard.....
Www.dormanproducts.com
justanengineer
07-04-2012, 08:25 PM
Crack open a cold one and yell, "hey y'all, watch this" first.
07-04-2012, 09:08 PM
Given the fact that rolled threads are 30-40% stronger than cut ones it's kinda of a bad idea right out the box.
If you have a local old time parts house nearby like a Napa or Car quest store your best bet is finding something close,same thread but bigger knurl and reaming the hub to fit.
kd4gij
07-04-2012, 09:42 PM
you can get a whole new hub at wally world for cheap. Any place that carries trailer parts will have them also
dp
07-04-2012, 10:06 PM
Good gnuz is he just needed a shoulder turned down a bit. I've replaced a bizillion studs over the years but never had to make one and that's just one of the kinds of things I don't care to make, given the risks.
