vinito
03-03-2004, 01:15 AM
I have a Cincinnatti Bickford drill press and Leblond lathe. Both of them need the gearbox oil replaced.
I searched this forum and read posts concerning lubricants, and learned a lot. I will be getting some Mobil DTE R&O circulating oil, but my question is: which viscosity is recommended?
The drill press tranny has spur gears and an oil pump and its max RPM is 2500.
The lathe has helical and spur gears and slings the oil (no pump) and max RPM is 1200.
The lathe manual (ca. 1951) specifies "500 sec. at 100 degrees F which compares to SAE-30". I have no manual on the drill press.
I imagine that both machines will work fine with the same viscosity. Am I wrong? and either way, should I use DTE heavy/medium or DTE light, or does it matter? (these are the two I am considering based on the forum discussions)
Thanks for any input.
Vinito
Vinito
