View Full Version : pantograph
black powder
07-20-2012, 05:50 PM
In one of the issues of Home shop Machinist,or workshop their was an article on building a small pantograph .Can anyone tell me what issue it was in?
oldtiffie
07-20-2012, 10:16 PM
http://www.google.com.au/search?q=pantograph&hl=en&rlz=1W1IRFC_enAU360&prmd=imvns&tbm=isch&tbo=u&source=univ&sa=X&ei=zhAKULT9FqaXiAe0s-G0DQ&sqi=2&ved=0CFwQsAQ&biw=1280&bih=545
http://www.google.com.au/#hl=en&gs_nf=1&cp=6&gs_id=o&xhr=t&q=pantograph&pf=p&rlz=1W1IRFC_enAU360&sclient=psy-ab&oq=pantog&gs_l=&pbx=1&fp=1&biw=1280&bih=545&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&cad=b
black powder
07-22-2012, 08:04 PM
thanks for your reply . what i am looking to make is something that i can copy the back side of pistol grips on . A pantograph or a duplicator that will hold a dremel with a router bit.
elginrunner
07-23-2012, 06:34 AM
I too have been looking for such plans. Small engraving for letters at 1/8", and .003 deep....
ammcoman2
07-23-2012, 09:27 AM
Martin Models http://www.martinmodel.com/ have the castings and they refer to Guy Lautard's 2nd Bedside reader for the plans.
Geoff
Chester
07-24-2012, 11:33 AM
This is probably the one you're thinking of....
http://i49.tinypic.com/2pzbaf5.jpg
Projects in Metal April 1995
The Artful Bodger
07-24-2012, 03:53 PM
Google 'copy router' and 'copy carver', they are just a little different to a pantograph engraver in that they lift the cutting tool according to the relief on what is being copied.
The Artful Bodger
07-24-2012, 04:05 PM
Most every pantograph copier I have seen for the home shop requires a model much bigger than the article being made, this has advantages but might not be what you need for copying existing pistol grips?
Try this site http://www.copycarver.com/ it even shows pistol grips being copied.
BTW, if making a size reducing pantograph it is useful to include a ratio of 2.54:1 which allows you to make templates using inch measurements and the finished product to be in metric.
oldtiffie
07-24-2012, 07:15 PM
In theory, on a manual pantograph, a larger model/master and smaller work-piece (achieved by reduction ratio) gives a job "smoother" and "more accurate" than the master. The reduction ratio can be set between pre-set limits.
The ratio between the master "follower" and the job cutter diameter/s has to be considered as well - unless a pointed follwer and pointed angraving cutter are used.
