View Full Version : Craftsman 101 Lathe Question
outsider347
07-31-2012, 04:16 PM
Hello
New guy here.
Just bought a Craftsman 101.28940 Lathe.
In the process of diss-assembly clean up & repaint. So far found & repaired several "cobbed" things & I like to know how things work prior to using the machine
It has a quick change unit & I'd like to remove the head & QC from the bed for more cleaning, check out & paint
Any reason I should not remove these from the bed
anything I should look for while its apart
And Any suggestions appreciated
Thanks for your response
Oldbrock
07-31-2012, 08:15 PM
Take pictures as you take the lathe apart so there's no guessing how things go back together. No problem stripping it down to it's smallest parts, you can check the condition of each piece as you clean it. If you mount an indicator on the tailstock base and indicate the ways you will get some idea of the wear, or not. Good luck on the rebuild. Peter
George Seal
07-31-2012, 09:31 PM
Outside
take the feed chart off there is a bolt underneath
remove the two bolts on the lead screw bracket
Any questions PM me
CCWKen
07-31-2012, 11:34 PM
Get a copy of the parts manual or snatch a copy of the pages from the link below. It will help during re-assembly.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Lathe-Parts/Model-101-28940/0247/0728000
outsider347
08-01-2012, 07:57 AM
Thank You Gents
I'll try to post some pic when I complete the proj
