Going thru a 12 in lathe I just bought.
The lathe had a "growel" coming from the QC box. Took it apart & the gear change shaft was bent. Ordered a replacement shaft as well as the long key that drives the gears.
Question is. How tight should the gears fit on the shaft with the key in place?. The gears slide over the shaft fine without the key. When I attempt to assemble with the key... super tight fit...would need a brass punch, which doesn't seem correct to me. Should the gears slide on the shaft/key easily ?
when I took it apart, the old key & shaft were "buggered up" pretty bad. Took a long time to get apart carefully.so I'm not sure how it was originality
Thanks for your help.
