View Full Version : Oil seals - online source?
Abner
09-20-2012, 02:18 PM
Hi guys,
I need a couple of seals, more specifically I need to order by ID & OD as the numbers the local bearing house says are not correct.
Thanks,
Abner
Dr Stan
09-20-2012, 02:51 PM
If you have local stores try Federated Auto Parts and NAPA. I've found both to be more like the "old fashioned" parts houses that can actually cross reference sizes to part numbers.
tdmidget
09-20-2012, 02:53 PM
Take your business to someone who cares enough to get you the right part what ever it takes.
09-20-2012, 03:11 PM
Oil seals come in standard sizes and it is amazing what fits what. The oil seals on the transmission of my Land Rover are identical to a common Chevy transmission seal. Same with the half shaft seals in the front drive.
JCHannum
09-20-2012, 07:47 PM
McMaster Carr lists them by ID OD & thickness.
http://www.mcmaster.com/#
Doozer
09-20-2012, 09:49 PM
Time after time, McMaster carr is just amazing.
Just say'in.
--Doozer
09-21-2012, 02:47 AM
Except they won't ship to Canada.
Abner
09-21-2012, 08:19 AM
Thank you JC for the McMaster link.
Had what I needed and online ordering was fast(WOW!)
JCHannum
09-21-2012, 09:11 AM
McM is hard to beat. Especially with ~$4.00 a gallon gas it is cheaper to just go to their website and know you are more than likely going to find what you need than driving around in hopes of finding it in your local area.
Delivery in my case is often overnight.
