The key with these things is being able to dump ALL the air in the tank as quickly as possible, as close to all at once as you can get. I've been pondering what the best valve is to use to do this. On mythbusters, they used a big butterfly valve that looked pretty good.
An interesting thing to note, one guy that competes at the Pumpkin Chuckin events, was on tv with his giant cannon, 2nd Ammendment. He said that he can get the same distance with 50 psi as he can with 200psi by timing the release of the air.
So Im only thinking about 100 psi max here, any suggestions about what valves to use? It seams that the valves are a closely guarded secret.
