Cruising EBoner looking at a few different DROs for my lathe.
A few look pretty cheap compared to some of the more well established names in DROs and I was wondering if anyone has any experience with some of these brand names.
SINPO - 2 axis DRO
Absolute/Incremental
~ Power : 100-240Vac , 50/60Hz
~M/I: MM/Inches conversion
~Radius/ Diameter selection
~Linear error compensation function
~Machine Reference
~9 Tool compensation
~200 work piece datum
~Power off memory
Electronica - 2 axis DRO
· Inch/Metric Display
· Line Hole Function
· Axis "Quick-Zero" Keys
· Grid Function
· Axis Set
· Linear Bolt Hole Function
· User Selectable Resolution
· Arc Contouring Function
· Half Function
· Radius / Diameter
· Distance to Go
· Tool Offset
· Center of Circle
· Taper Function
· Center of Line
· Polar Coordinates
· ABS/INC Coordinate Display Switch
· Easy Setup Mode
· Calculator
· Axis Summing
· Sub Datum Memory
· Vectoring Function
· Power Off Memory
· Pre-Set Depth (PSD)
· Bolt Hole Circle
· Touch Probe Input (400 Series Only)
· Bolt Hole Arc
· Linear Error Compensation
Any thoughts ??
SINPO - 2 axis DRO
~Machine Reference
~Power off memory
· Grid Function
· Axis Set
· Half Function
· Radius / Diameter
· Distance to Go
· Tool Offset
· Center of Circle
· Taper Function
· Center of Line
· Polar Coordinates
· Easy Setup Mode
· Calculator
· Axis Summing
· Sub Datum Memory
· Power Off Memory
· Bolt Hole Circle
· Bolt Hole Arc
Any thoughts ??
