View Full Version : Which bandsaw blade length?
CMcmillan
10-13-2012, 09:43 PM
edit. . . . . . .
Found the correct size on the site. Thanks for the help
gizmo2
10-13-2012, 09:52 PM
Well, 12" to the foot, so 5 feet is 60", leaving 4 1/2" so 5'4 1/2" is the blade you're looking for.
LKeithR
10-13-2012, 10:22 PM
Which is 64-1/2"--same as the dimension used in the first post...
CMcmillan
10-13-2012, 10:40 PM
http://www1.mscdirect.com/cgi/NNSRIT2?PMAKA=60367471&PMPXNO=8857014&cm_re=ItemDetail-_-ResultListing-_-SearchResults
http://www1.mscdirect.com/cgi/NNSRIT2?PMAKA=56380249&PMPXNO=3842171&cm_re=ItemDetail-_-ResultListing-_-SearchResults
different model numbers but same specifications?
And then there is a different one here http://www.amazon.com/5-4-1-14-18-0-025-Bi-Metal-DIEMASTER2/dp/B007A613L2/ref=sr_1_5?ie=UTF8&qid=1350180936&sr=8-5&keywords=Lenox+5%274+14%2F18
What is the difference between these? Theyre all the same size and specs of what I need but all three have different model numbers
