View Full Version : OT replying to posts
duckman
10-16-2012, 11:21 AM
Is there any way to know which posts you've posted to, like on the PM site you get a little green thing showing that you've replied to a post.
justanengineer
10-16-2012, 11:43 AM
Click on your name in your first post, then click "View Forum Posts." This open a list of them.
Mcgyver
10-16-2012, 11:51 AM
I see a green circle with a check to the right of the word "views" for threads i've posted to.
duckman
10-17-2012, 12:36 PM
OK I replied to post and was named as last to reply, do not see any green thing showing that I'd replied to a thread, what gives.
Mcgyver
10-17-2012, 01:27 PM
here's what i see....start going through the settings?
http://i20.photobucket.com/albums/b201/michael0100/greendot.jpg
duckman
10-17-2012, 02:16 PM
OK Mcgyver I see your screen shot and the green thing but it never shows on my screen, so what is going wrong?
George Bulliss
10-17-2012, 02:30 PM
Although the option to display threads-posted-in is turned on in the board settings, we lost the graphic notice when IT reworked the status envelopes seen at the left of the thread title.
What Mcgyver is seeing is the thread subscription notice, which should work as an alternative.
To set it up, go to General Settings/Default Thread Subscription Mode and select From My Control Panel Only in the menu options.
This should do the trick, I think.
George Bulliss
10-17-2012, 03:24 PM
Duckman,
I went ahead and made the change for you. You can change it back yourself by going to your settings page or just give me a shout. This should work on all of your posts from here forward, but will not show for posts made prior to the change.
duckman
10-18-2012, 08:11 AM
Thanks George that's just what I wanted, didn't know how to do.
dockrat
10-18-2012, 10:25 AM
that works :)
bborr01
10-18-2012, 10:58 AM
Duckman,
Thanks for bringing this up. I have changed my settings and will like being to be able to see what threads I have replied to again.
Also thanks George for the instructions.
Now to hit "quick reply" and see if it works.:)
wern
10-18-2012, 02:26 PM
Had the same problem, see if this works.
