View Full Version : Adjusting heavy milling head to an angle. Dealing with weight.
TR
11-18-2012, 10:35 AM
I have a mill drill which allows the head to be adjusted. There are three bolts which hold the head in place. Now the motor and gearbox are incorporated in the head. Makes it very heavy. I find it could be dangerous tilting the head to say 30% because it could fall to one side and cause damage. Do machinist actually adjust the head to other angles ? Are there techniques one would use ?
This is my mill drill from a few years ago.
http://i663.photobucket.com/albums/uu354/topari/DSCN2430Small.jpg
Mcgyver
11-18-2012, 10:48 AM
It may not be that bad. To some extent its counter balanced. my XLO has a worm and wheel but you still want to take most of the weight by hand....as well you don't want to rely on the worm; ie something could break/be broken. So even on a full sized one, where it isn't that well balanced, its no big deal to take the weight over to say 45 degrees which I can do on single handed. One hand on the head, one on the crank.
A better procedure is to have two people; one to bolt and one to spot.
bborr01
11-18-2012, 10:50 AM
TR,
Most of the
Bridgeports and clones have a worm gear for adjusting the head tilt or nod. I don't know how you would control the tilt on a machine like yours.
11-18-2012, 11:14 AM
Simple solution for tilting the head safely is a small block and tackle between the top of the motor and ceiling.A 2 or 3 sheave block will give you good control add a small handcrank winch if you want positive positioning capability.Something like a commercial window blind winch would handle it along with the blocks.
http://www.na.lv/eng/sale/?c=154&p=382
Dunc
11-18-2012, 11:40 AM
I have a much smaller mill but the advice I received (believe it was on this forum tho I can't quickly retrieve the post) was to avoid tilting the head and tilt the work instead. Saves all the hassle of re-tramming every time the head is offset.
loply
11-18-2012, 12:27 PM
I've got more or less the same machine.
I've tilted the head several times, if you don't slacken the bolts off too much it's really not dangerous. It's actually quite hard to move the head.
To get it back in tram I would suggest making two brackets like these -> http://bbs.homeshopmachinist.net/showthread.php?p=761598#post761598
At least, if the bore betwixt head and saddle on yours is as bad as mine, you'll need them.
Rich
Black_Moons
11-18-2012, 12:38 PM
Rich
Agreed, those heads don't move easy.. rather.. well bound, since most of the weight cocks the t nuts and such.
I loose my mine slightly then have to hit it with a huge dead blow rubber hammer to move it any... For precision adjustment (traming) I tighten the bolts slightly and hit it even harder.
Mcgyver
11-18-2012, 12:51 PM
of course there's always the "it depends".....but I disagree with this advice in principal in that tramming the mill head is part of good workmanship. Its not a one time thing; the mill head goes out of tram with use and needs to be resent periodically....an approach to working that avoids tramming isn't a good approach. if the work is very light it won't matter, but in general its often a more solid set up tilting the head and isn't required that often ....the mill head tramming gets done more often than head tilting (at least thats been my experience)
LKeithR
11-18-2012, 01:13 PM
Have to agree here. When I first started using a mill--years ago--I avoided tilting or nodding the head and had some real fights with awkward setups. I got to watching and talking with a couple of old hand machinists at other shops and soon realized that they seldom hesitated to move the head if necessary. Get the work mounted solidly on the table and then bring the tool into alignment was their motto. The trick is to "practice" tramming the head so it becomes second nature; so you know almost instinctively where to make the adjustments and how much the head moves when you do the final tightening of the bolts. It helps to have proper tools, too. Although I get by fine with a single dial indicator on a bent rod one of those "two-headed" devices works a charm. I don't own one but I've played with a borrowed tool and I really have to get busy and build myself one. One of those with a little trig would also make it a snap when you're setting up to take an angled cut...
willmac
11-18-2012, 02:48 PM
This is very good advice. In fact it is more than that - if you don't check tram regularly you will eventually regret it with a vengeance. I once spent about 5 days machining two matched parts in some expensive Aluminum alloy. They were machined practically all over, had many tapped holes and two large bores. I made the bores first without any problem, exactly to size and was very pleased with myself. It was only when I had finished the parts and tried to assemble them with other parts that I found that the bores were not quite square, and for this job they had to be very close. The parts were scrap - and I still have them as reminders to myself - always check tram before boring.
SGW
11-18-2012, 03:13 PM
I don't have the same milling machine but mine has the same problem. Loosen the 3 bolts and no end of excitement is just waiting to happen. I find that if I loosen two of the bolts so they are not binding anymore, then stand on the side the head is going to be tilting toward and carefully loosen the 3rd bolt just enough so the head will move with some effort, keeping the wrench on the bolt in the process for instant snugging-up if necessary, I've managed not to kill or maim myself yet.
Another trick I've used for "large" tilts approaching 45 degrees is to tilt the head until I get nervous (maybe 30 degrees), then put a wood block between the side of the head and the table so the head can be tilted in a controlled way by lowering the knee. Since the block's contact point on the side of the head will move in an arc, this stunt takes judicious observation and re-adjustment while you're doing it.
mike4
11-18-2012, 08:19 PM
As was stated earlier , its no big deal to tilt the head for some setups as it can be safer than some weird hold down setup.
When the job is completed part of the next setup automatically is check the tram and make sure that any other adjustments were returned to normal as well .
its all part of the job.
Michael
TR
11-18-2012, 09:14 PM
Rich
Rich, I like your brackets. I will try the brackets.
Good advice Guys. Thank you.
I do not post many questions, but seem to solicit good discussions. This is why I always return.
dave5605
11-19-2012, 11:46 AM
Keith mentioned using the dual dial teaming device with trig to set the head on an angle. Not sure how that would work, other thsn fir a very shallow angle, but you can use the dual dial trimmer with a sine plate to set a precise angle. Just set your angle in the sine plate and adjust the mill head till both dials on the team met read the same when against the sine plate. Not my idea. I saw it on one of the websites selling the two dial trimming device.
GNM109
11-19-2012, 03:51 PM
I move the head on my Webb mill when required and always re-tram afterwards. I'm careful to support the head when moving so as to take the load off of the worm gear in the center of rotation or for nodding. Also, when I return the head to its vertical position, I don't use the worm by itself to do the raising. I keep upward pressure on the head while turning the worm drive shaft in order to relieve strain on the worm gear. I had the head off of the mill when I was refurbishing it and those gears don't appear to be all that sturdy.
I've read about broken worm drives on Bridgeport and similar mills apparently from using the gears alone to do the lifting.
Ron of Va
11-19-2012, 04:49 PM
Chuck up a piece of drill rod in a large end mill holder. The longer the better. Extend the quill, and you have a nice lever on at least one end to help maintain control.
(Donít use a drill chuck for this.)
Mike Nash
11-19-2012, 05:00 PM
With just a little bit of ingenuity, the table could then be used to micro-adjust the head via Ron's drill rod. Just don't cause a situation that's trying to bend the bar.
firbikrhd1
11-19-2012, 07:44 PM
I'll add to Mike and Ron's posts and suggest putting a long eye bolt of as large a diameter as possible in a collet or a drill chuck and attaching a short piece of chain to a "T" nut with short eye bolt in the "T" slot of the table. Lower the table until the chain has no slack, loosen the bolts and slowly raise the table allowing the head to tilt slowly and precisely as the table rises. When it is in the preferred position tighten the bolts. To put things back reverse the process assisting the table with upward pressure on the head.
This is only a suggestion, I haven't tried this method as my mill has a worm gear and crank that rotates the head.
Mike Nash
11-19-2012, 08:15 PM
Here is a quote from Aaron Moss's original Industrial Hobbies web site on tramming the '45 series head.
Now, I don't have a picture of this, but it's what I do for the head. Just in front of the collar on the head you will notice there is a dead space up where the drain plug is at. I drill a 7/8" hole on both sides of the head here, as close the the back of the head as I can get, and through this "dead spot". This allows me to put a 3/4" steel bar about 4' long through the head to get some leverage when tramming. This way I can leave the bolts pretty tight and muscle the head around just a pinch when I need to.
I haven't done this, nor have I looked at mine to even see exactly where this location is. If you try it and it doesn't work out, remember, that is a quote!
