View Full Version : New hand wheel handle
lbhsbz
11-19-2012, 12:09 AM
I bought a Cadillac lathe a while back...had a bolt in the carriage hand wheel. I've been to busy to do anything about it until today. I don't like the stationary handles and I didn't want a hole in the end. I dug through the bin and found some bearings I'd bought a while back..0.375 ID and .910 OD. I bored out a piece of 1.125 7075 to accept the bearing as a press fit, as well as a retainer I turned to reinforce the press fit, then cut 3/4-16 threads on the other end, with a 1/2" through hole for an Allen key to access the bolt that holds it to the hand wheel. I tapped the same 3/4-16 female threads in
another chunk of 7075 to thread on offer the bearing assembly is fastened. Came out nice,makes the lathe a bit more pleasurable to use
http://img.photobucket.com/albums/v201/machschnelGTI/63E98BD9-8B4C-484A-8A72-D1B5C0FFE6FE-1041-000001CEAD514BF2.jpg.
http://img.photobucket.com/albums/v201/machschnelGTI/F6CE7C80-3C04-4797-B6D8-307295B3CC3C-1041-000001CEB1DDAC99.jpg
uute
11-19-2012, 12:23 AM
Very nice.
A job done right the first time that will be a pleasure to use for a lifetime.
uute
sasquatch
11-19-2012, 08:04 AM
Great fix. So often we see handwheels of all sorts with a lowly old bolt stuck in there.
