View Full Version : 9X20 drive belt.
Bob Fisher
11-19-2012, 08:44 PM
Where is the best source for the skinny belt used on these lathes? I have found several places on the web, but $30 seems a lot for this belt. I can buy a REAL V belt from my local hardware store for about $6 or $7. Mine is about 15 yrs old, and has cracks, but still works. I realize that the strength is on the top of the V much like a serpentine belt on a car, but I would like to lay In a spare or two anyway. Bob.
11-19-2012, 09:10 PM
That takes a Gates 5m710 polyflex belt.Any good industrial belt supplier will have them.This is one-
http://www.royalsupply.com/store/pc/Gates-5M710-Polyflex-V-Belt-89020710-p40301.htm
There are several others,Applied Industrial Technologies is one-
http://www.applied.com/apps/commerce/catalog/catalog.do?e=2&c=585
Motion Industries is another-
http://www.motionindustries.com/motion3/jsp/mii/productSearch.jsp?CATEGORY=1&LANGUAGE=0&PARAMETRIC_LEVEL=1&BUS_ACTION=PARAMETRIC&SEARCH_DESC=&SPECIAL_SEARCH=CGC!0301&lvl1_cgc=03&lvl1_descr=Mechanical%20Power%20Transmission&PARAMETRIC_ACTION=01Belts%20%26%20Sheaves
Forgot to add,check the length of your existing belt as it's possible they may have changed the design of the lathe over the years.
danlb
11-20-2012, 12:32 AM
I found that different years used different lengths. When I bought mine it had a belt so tight that changing to the other pulley was a chore. If I recall correctly, the 710 is 710 millimeters. The replacement was 720 and works fine on all settings.
Dan
Guido
11-20-2012, 01:22 AM
Vbelts4less.com
Pair of 710mm metrics plus ups-----36 bucks
Guido
tom in nh
12-30-2012, 07:05 PM
I am feeling generous - will start a new thread.
