I'm not sure if this is a problem or not, but I was testing feeding and ejecting with some ammo I got, there is several differing kinds from various makers dating from 1928 to 1978, most being made in the 30s and 40s, it feeds and extracts fine but the ejector seems to slip over the edge of the cartridge leaving it hanging on the bolt face, once in a while it will kick one out, is it meant to do this because the cartridge hasn't been fired, or do I need to do some adjusting of the ejector so it more positively engages the head of the cartridge?
Also, yes the ammo was all live, however there is no safety concern as the firing pin is not installed in the gun, I wouldn't ever test an action with live ammo exept at a firing range, in this case I have no dummy's for this caliber, the firing pin had been removed and the muzzle was pointed in a safe direction just in case.
