View Full Version : Milling hardened steel (10/22 bolt)
S&S_ShovelHead
12-19-2012, 03:39 PM
Im trying to mill a 10/22 bolt. Fairly unexperienced machinist. Tried using a standard cheap chinese endmill hoping it would work if I took really light cuts, didnt even scratch it before totaling the end mill. I'd rather not anneal it if possible. Will a carbide end mill work?
tdmidget
12-19-2012, 03:51 PM
Carbide might work in a very rigid machine. But why? The weight of the bolt is critical to the operation of the action. How will you compensate for the missing weight?
Toolguy
If your mill is rigid enough it will work fine. If you have a springy hobby mill it will bounce around till the carbide is chipped to pieces.
MasterMaker
12-19-2012, 03:55 PM
Carbide will work, quality hss will also work but quality hss will probably cost more than cheap carbide capable of doing the job.
Ruger has a reputation(at least with the gunsmiths I know) for having harder and tougher steel in them than most other guns.
What milling machine do you have?
S&S_ShovelHead
12-19-2012, 05:39 PM
Rf-45
Toolguy
12-19-2012, 05:54 PM
I would try carbide on that machine. Do not try to climb mill though.
Sparky_NY
12-20-2012, 12:41 AM
I customized a 10-22 a few years ago which included milling on the bolt. I did it on my bridgeport with a carbide endmill with no problem at all. As always, watch your speeds and feeds. I am betting you had the speed way too high on your first attempt for hard steel. A cheapo endmill didn't help matters either.
Ron of Va
12-20-2012, 09:36 AM
I drilled a 10/22 bolt for the purpose of lightening it to shoot subsonic ammo in an integrally suppressed barrel.
The outer surface is very hard, but once you get into it about 1/16 of an inch, it drills just fine. I burn up the point of the first drill bit I tried. I slowed down, and used cutting oil after that. So once you get through the skin, it will go just fine.
http://www.hunt101.com/data/500/medium/802bolt.jpg
