View Full Version : Odd ball threaded studs
1-800miner
01-19-2013, 07:03 PM
I need some threaded studs that are different diameters on each end. 5/16" on one end 3/8" on the other.
Anyone ever see such a thing? and if so what do you call them?
If I have to I will make them.
Oldguy
01-19-2013, 07:14 PM
Try McMaster - or a real auto parts store. I remember seeing the stepped studs in the Dorman drawers of automotive fasteners many years ago.
Glenn
1-800miner
01-19-2013, 08:56 PM
Well I searched Dorman, Mcmaster, Grainger, and Fastenall.
No luck. What do you call the d**m things?
I know that someone makes them.
RussZHC
01-19-2013, 09:07 PM
http://www.bdcoldheadedproducts.com/double-end-studs.php?item=Double%20Ended%20Studs%20Specials
"double ended studs"
Edit: http://www.rbssuperchargers.com/Products.cfm?pn=2620-0001&pID=6669 little bit different configuration
http://www.amkproducts.com/bulk2.asp?code=7420&title=Studs+-+Hex+Collar with a hex collar between
http://www.autozone.com/autozone/accessories/Dorman-AutoGrade-5-16-in-18-x-3-8-in-and-5-16-in-24-in-double-ended-stud/_/N-255s?itemIdentifier=894683
http://shop.advanceautoparts.com/buy/products/167652-double-ended-stud-5-16-18-x-3-8-inch-5-16-24-x-1-2-inch-by-dorman-autograde-part-675-090.html
www.specialty-fasteners.com/images/SpecialtyCatalog-19.pdf they call them "step studs"
sasquatch
01-19-2013, 09:17 PM
i have seen them in old small engines i scrapped, they were i think head bolts/studs.
Don Young
01-19-2013, 09:56 PM
We used to call them 'bull studs'. I think I have seen them called 'double diameter studs". They used to be pretty common to repair stripped holes for engine manifolds.
