3/4 20tpi nuts
  • mike4
    • Aug 2010
    • 1761
    3/4 20tpi nuts
    Has anyone come across a source of 3/4" 20 tpi nuts?
    I have a small shaft which is in a machine , it is held in place by a nut which is dual purpose , 1 to hold the shaft in and 2 to put some preload on a couple of tapered roller bearings .
    I dont want to make another shaft as it is not damaged , just some foole has hacked at the nut with a chisel to tighten it , ( normally a thin walled socket is used ", but somewhere during the life of this tractor someone had a BUBBA moment or two.
    Now I have to find and repair all of the previous acts of butchery and repair the original faults along with the results of the butchering .
    Michael
  • lakeside53
    • Nov 2007
    • 10512
    #2
    McMaster has them in stainless for about $18 each
    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
    For that price (plus shipping) I'd make one (no matter how long it took).
    • mike4
      • Aug 2010
      • 1761
      #3
      I have looked for a small boring bar setup to make one and if I bought the tooling to make the nut it would be a lot more . Does McMaster sell in small quantities ?
      Another alternative if I want to torture myself is to buy a couple of Chinese made taps and try to thread a piece of mild steel , might take a while if I can believe all the naysayers about Chinese tooling.
      I havent tried their taps or drills yet and this might be a good time .
      Michael
      • oldtiffie
        Member
        • Nov 1999
        • 3963
        #4
        I am pretty certain that McMaster-Carr will not sell to Australia or a lot of other countries external to the USA.
        • oldtiffie
          Member
          • Nov 1999
          • 3963
          #5
          Michael
          I have quite a few of them and they are very good - perhaps it seems to be a case of where you buy them and what you pay for them.
          3/4-20 is a very odd size - why not make a tap from silver steel (ie O1 in the USA)?
          • mike4
            • Aug 2010
            • 1761
            #6
            Thanks for the replies , I have ordered two taps from a chinese supplier and am very interested in how they perform , as there have been a lot of derogatory remarks posted on a lot of sites .
            I also found a supplier in England who will ship to Australia in one off quantities . I didnt wat to replace the shaft as when I got a service manual that thread is used for a specific reason , adjustment of preload is easier than with the more common 3/4" 16tpi .
            So now I have a nut and two taps on the way .
            Internet search pays off again and this forum is also very helpful..
            Michael
            • bob ward
              • Jun 2007
              • 783
              #7
              I've found this DIY tool to be useful for small size odd-bod internal threading jobs.
              • John Stevenson
                • Mar 2001
                • 16177
                #8
                At 3/4" it's one of the British standard cycle range, normally BSC is 26 all thru but the larger sizes can be 24 or 20.
                I have bought some Trapezoidal taps from China, only place i can find the size and pitch and they have been good but they were about £30 to £40 a pop, not cheap 3 for a pound rubbish.
                • Mcgyver
                  • Mar 2005
                  • 13411
                  #9
                  unless you need to make a bunch, why not just single point it? 3/4 is large in that there is tons of room to get in there....grind up a bit of hss and away you go.
                  located in Toronto Ontario
                  • duckman
                    • Nov 2009
                    • 1139
                    #10
                    Go to any Chevrolet dealer and ask for an axle nut off of a Corvette rear axle, they are 3/4-20 I made some axle drivers for a friend so I have a set of taps.
                    • lakeside53
                      • Nov 2007
                      • 10512
                      #11
                      But there's a bunch of forum member that would do that for Mike!
                      • firbikrhd1
                        • Mar 2001
                        • 1610
                        #12
                        +1 on Mcgyver's post, just grind up an internal threading tool from HSS. duckman's solution might be the easiest if you have a Chevy dealer nearby. Were it me, I'd make one just for the challenge and experience, but I enjoy a challenge and the pleasure I get from successes, even small ones. In fact, I've been known to spend $5 to make something I could buy for $6. Crazy? Maybe.
                        • wtrueman
                          • Mar 2008
                          • 451
                          #13
                          Duckman: This IS what a forum like this is SO useful for!! Wayne.
                          • wbleeker
                            • Nov 2001
                            • 453
                            #14
                            I have bought spiral point taps from CTC tools in Hong Kong Mike and I did a tapping job the other day with them where I tapped 100, 8mm holes and 100, 6mm holes with no problems. I am waiting on fine 10 and 12mm taps from China so I will see what happens when they get here.
                            Will
                            • mike4
                              • Aug 2010
                              • 1761
                              #15
                              I have bought er collets from CTC and they are not giving any problems .
                              I dont have any bias for or against any country of origin.
                              The only thing is that equipment that is offered for a purpose is fit for that purpose .
                              I dont look for the cheapest , I look for quality and China can and does produce that if you are prepared to pay for it.
                              I am currently waiting for a nut from an English supplier as there is a time frame for the repairs.
                              The taps will be used to make spare locknuts for the same customer as a modification.
                              Michael
