View Full Version : Anodizing Question...........
JoeLee
02-15-2013, 02:39 PM
Does any one know of any small shops that will anodize a few parts for less than an arm and a leg???? maybe a couple fingers!
I have the need to anodize some small parts, usually the big shops either have a minimum on pieces or are just way to expensive.
The only alternative I've found is Birchwood Casey's aluminum black, but thats like cold blue for steel, a chemical staining process.
I doubt it's as durable as an anodized fiinish.
JL...................
Toolguy
02-15-2013, 02:45 PM
I have not had any luck at all with B/C aluminum black. Tried it several times, not even close to anodizing.
demerrill
02-15-2013, 03:13 PM
Here's my collection to DIY anodizing links:
http://www.homemodelenginemachinist.com/f25/anodising-13211/
http://www.observationsblog.com/4/post/2011/10/anodizing-and-dying-aluminum-without-battery-acid.html
http://www.focuser.com/atm/anodize/anodize.html
http://engineeringhobbyist.com/projects/completed/anodizing/
http://www.thirdgen.org/anodizealuminum
David Merrill
Weston Bye
02-15-2013, 04:34 PM
Another vote for the DIY links, but...
I do my own anodizing, but will admit that it is a chore setting up, doing the actual work, and then cleaning up afterwards. Figure on a whole Saturday afternoon, even for just a few parts. Also, figure out some safe storage for a gallon or so of sulfuric acid and maybe some caustic lye in between sessions.
JoeLee
02-15-2013, 05:15 PM
That is what I didn't want to get into for a few small parts.......... a whole day's worth of work plus clean up. I don't have any of chemicals or electronic stuff and don't plan on getting into it either. I have done hot blue and thats enough work and clean up.
I'll check the sites.
JL...........................
Mike Folks
02-15-2013, 06:46 PM
If you need to remove Anodizing from Aluminum parts, any of the stove cleaners will work, after applying it, just do a good rinse, followed by soap and water & rinse. I like easy off oven cleaner.
RWO
02-16-2013, 01:22 PM
This company does small jobs: http://www.usanodizing.com/index.htm jobs Their website is aimed at gun makers, but they will do other kinds of stuff, plus that can do Type III if need be.
RWO
Ridgerunner
02-16-2013, 01:36 PM
RWO
Their contact page says they are not accepting any non-production work now.
