View Full Version : High current 12 volt relay
radkins
02-19-2013, 12:42 PM
I need to power a 12 vdc fan on a hyd oil cooler, this fan draws about 40 AMPs cont. but the 40 Amp Bosch type relay I am using now does not last more than a few days. I have several of these relays with matching sockets so I was wondering if it would work to use two or more in parallel to carry the load?
gzig5
02-19-2013, 12:49 PM
We parallel relays all the time for the pre-charge circuits in our servo drives. I don't think it is the perfect solution because the contacts never make all at the same time, but is it does seem to work well enough especially if the current inrush can be limited. Most of these are automotive relays.
If you are handy with electronics a power FET circuit (solid state relay) may be a more reliable solution than dry contacts. SSR's are commonly available but not really cheap, but you can build an equivalent circuit pretty easily.
Timleech
02-19-2013, 01:00 PM
Starter relay?
Tim
lakeside53
02-19-2013, 01:14 PM
Parallel rarely works well this situation (contact timing on both start and release).. The problem is not the continuous current, but the startup, or, there is no snubber across the contacts. Personally, I'd toss it and put in an SSR. Maybe $10-$20...don't forget the heatsink.
Of course, as suggested above, a starter motor solenoid (find one on an old rider mower etc) is dirt cheap and will most certainly have enough capacity.
flylo
02-19-2013, 01:17 PM
I've used the old style Ford starter relays that mount on the inner fender in many apps.
MaxHeadRoom
02-19-2013, 01:25 PM
If the relay has sockets then it does not seem like a 40a rated relay, unless that is an AC inductive load?
For 40amps DC I would think the minimum is a Special Purpose contactor, these are specially made for high duty cycles and other features.
A 40amp inductive load is a considerable load to switch, a DC contactor is usually required, these have special conductors around the contacts for arc blow out, this can also be done with a blow out relay with a magnet.
Also suitable arc chutes are fitted between contacts.
A solid state solution should also work.
Max.
MrSleepy
02-19-2013, 01:39 PM
For low voltage DC applications the contactors used on golf buggys are some of the cheapest and most rugged I've found .
The coils are in the 12vDC ->48vDC range and the contacts are usually rated in the 100-400amp range.
http://www.ebay.com/sch/i.html?_sacat=0&_nkw=solenoid+12v+golf+cart&_frs=1
Rob
radkins
02-19-2013, 01:40 PM
I thought of using a starter solenoid (relay) but all that I have found, including the Ford, are only rated for intermittent duty. There are automotive factory fan relays out there and aftermarket fan relay kits but even the factory fan relays alone, at least those with the high current ratings, are around $150. Since I had the 30 Amp relays and some wired sockets on hand I thought maybe the parallel idea might work but apparently not and for the same reason I was already concerned about, failure of both to carry the start load equally.
lakeside53
02-19-2013, 01:44 PM
Rob
Yes, can't beat those. And they are continously rated.
radkins
02-19-2013, 01:48 PM
Rob
We must have been typing at the same time.
I just took a very quick look at that link but that looks like exactly what I need, I had searched E-Bay for relays and only found more of the same (or similar to) of what I had. I did not think to search for continuous duty solenoids. Thanks
duckman
02-19-2013, 01:53 PM
It took me about 30 seconds to find these 80 amp 12 volt relay, http://www.jamestowndistributors.com/userportal/product.do?part=77011&engine=adwords!6456&keyword=product_ad_12579&type=pla and not expensive
jim davies
02-19-2013, 04:17 PM
The old style Ford fender mount starter relay, available in both remote and case grounded versions is also offered as a continuous duty version by most suppliers like Standard. Last time I looked in the book, there was an asterisk by the part number in the line leading to the continous duty version p/n at the bottom of the page. They work, they are cheap and convenient to mount and use. I have used them in remote battery setups for years.
The difference is higher resistance in the primary windings for the continuous duty version, easily checked with an ohmmeter.
MaxHeadRoom
02-19-2013, 04:41 PM
40amp DC SSR.
http://www.futurlec.com/RelSS.shtml#DCDC_SSR
Max.
winchman
02-20-2013, 03:10 AM
The intermittent duty and continuous duty automotive-type solenoids are the same except for the coils. The continuous duty solenoid has a higher resistance in the coil so it won't get hot when it's on for a long time.
You could probably use one of the intermittent duty solenoids if you put an external resistor in the circuit to the coil. Be careful with the Ford solenoids that have a snubber diode on the coil circuit. Reverse polarity will ruin it, and the solenoid won't work.
02-20-2013, 09:29 AM
So long as you use the *DC* variety, AND so long as you can deal with added losses and voltage drops, the DC SSR is fine.
A mechanical relay has little voltage loss, and needs no heatsink.
flylo
02-20-2013, 12:22 PM
I've used the continuous duty ones many times & never had a failure & there easy to get.
Frank K
02-20-2013, 07:37 PM
Do a search on Tyco BR5000 relays. They're small, 12v coil and contacts rated for 70 amps. I've used them for powering up communications stacks in emergency vehicles.
robosilo
02-21-2013, 04:42 AM
Trombetta, Albright, and White-Rodgers are a few Mfg's that make high amp relays for golf carts and electric vehicle projects. If you're ambitious enough you could buy a high wattage transistor/MOSFET and make your own SSR for about $15-20. I've gone that route myself for a few projects.
Bill736
02-22-2013, 10:26 PM
http://www.surpluscenter.com/electric.asp
Surplus Center ( Burden's) also has a good selection of inexpensive solenoids.
