View Full Version : Machining small valve spindles
kenrinc
03-26-2013, 03:07 AM
I'm making some valve spindles for some small model globe type valves (PM Research if your familiar with those). The instructions don't mention any particular way to machine the spindle. The material is 303SS and I'm starting from 1/4" in dia rod. The issue is that the work sticks out from the chuck over 1.7" and the obvious deflection is making it difficult to complete the part. I've taken apart a few of these type of valves and I see no obvious center holes for possible holding with the tailstock center. A couple valves will have longer spindles. There is no mention as to whether to do the valve seat first or the handle side first. Obvioulsy trying to do it in a way that allows me to keep everything concentric. I'm looking for suggestions. It's funny, when searching around about making these valves nobody ever seems to mention any issues machining this part LOL... I think some decided to make the spindle from other material other than SS (bronze or brass).
Looks similar to this guy here:
http://kenrinehart.org/spindle.JPG
Ken-
Jaakko Fagerlund
03-26-2013, 04:59 AM
You can always make it longer, put a center in it and then after its done, just cutoff the excess. And the seating can be cut in the same chucking, just grind a form tool or even better, use the compound to feed in the proper angle. Using a parting tool to make an ending groove first helps.
SGW
03-26-2013, 05:31 AM
You could use a female center -- chuck a small bit of rod in the tailstock drill chuck and run it into a small center drill held in a collet.
I assume you know about extending the stock in stages ---- turn down, say, 1/4", then pull a bit more stock out and turn the next 1/4".
tdmidget
03-26-2013, 07:44 AM
There is no reason that you can't have a small center hole in the bottom of the disc. What you have there is a stem and disc made in one piece-valves do not have "spindles". In a globe valve the disc is a loose fit on the stem so that it can self align with the seat. How are you addressing this? It would work with an elastomer seat but otherwise the alignment of this part to the seat will be critical.
JCHannum
03-26-2013, 09:59 AM
I have made a couple of smaller versions of these valves. Jaakko F's procedure is roughly the way I accomplished the task. Sharp tooling and light cuts are the order of the day.
They more closely resemble plug valves than globe, so TDM's post can be ignored.
Mcgyver
03-26-2013, 10:43 AM
small stuff like this is doable by two methods i've used (and there may be many more) that don't use a centre. You either keep extending the work out (what a swiss lathe does) and machining a bit OR start with larger stock where 1.7 inches isn't too much overhang. For the first, I like to turn a length down to some dimension then use a collet. The second is very versatile and you do some neat stuff - its one way to turn very small diameters of some length, say 1/16"
if you can figure out how to use centres that makes it so much easier. if there can't be a centre hole in the finished product, have a sacrificial bit that gets machine off afterword.
kenrinc
03-29-2013, 01:57 PM
Thanks for all the replies guys. Appreciate it. I tried again tonight and got much better results. Still sort of mystified as to have the disc at the chuck end or out in a center on the tailstock side. Tonight I just faced the stock, drilled small center and then cut the disc/valve angles. Then pulled out about 2" or so and held the end in a center. Was able to get everything done but doing those threads in the center is a bit dicey. Didn't think much about it at the time but I obviously can't get my die holder that far in on a rod that long. Looks like I'll have to single point them.
Ken
tdmidget
03-29-2013, 05:16 PM
You obviously don't know what a plug valve is.
http://www.google.com/search?hl=en&site=imghp&tbm=isch&source=hp&biw=1375&bih=760&q=triumph+tr6&oq=triumph+tr6&gs_l=img.12..0l10.4280.8727.0.12176.11.8.0.3.3.0.1 51.1090.0j8.8.0...0.0...1ac.1.7.img.evdXbAWWQvU#hl =en&site=imghp&tbm=isch&sa=1&q=plug+valve+parts&oq=plug+valve+parts&gs_l=img.12..0i24.240970.258752.0.262214.26.23.0.3 .3.0.209.2520.7j15j1.23.0...0.0...1c.1.7.img.-uapoQdn7Tc&bav=on.2,or.r_qf.&bvm=bv.44442042,d.cGE&fp=1cc5073de5bd4a47&biw=1375&bih=760&imgrc=yN6pxgUI09y2zM%3A%3BP188IEhifN42wM%3Bhttp%25 3A%252F%252Fwww.novabizz.com%252FValve%252Fimages% 252FPlug_Valve.jpg%3Bhttp%253A%252F%252Fwww.novabi zz.com%252FValve%252FManual_Plug_Valves.htm%3B226% 3B216
JCHannum
03-29-2013, 08:16 PM
Actually I do. There are globe type with plugs rather than discs to provide a throttling function. These are also referred to as plug valves.
Jim Hubbell
03-29-2013, 08:49 PM
I have made several PM research valves in both globe and angle style. No problems with seating and/or leaking. One is set up as a throttle for the engine.
Tony Ennis
03-29-2013, 08:50 PM
Can you make a box tool for it?
kenrinc
03-29-2013, 11:43 PM
LOL. Well I ended up making a jig so I could rechuck the work piece to do the threading. Valve body is 8-32 so is the spindle thread yet they don't actually fit. Is there a trick to taping brass and stainless? I allowed probably .010 under for fit. Tap runs into the brass fine. Die runs over the spindle fine. Spindle does not fit in threaded part of bonnet. Tap does run through die fine. Taped a scrap piece of steel with the die, doesn't fit.
Ken-
Toolguy
03-30-2013, 12:28 AM
If you have an adjustable split die it needs to be adjusted smaller.
JCHannum
03-30-2013, 09:56 AM
Can't have it both ways. I work on these things. Plug valves are plug valves. Globe valves are globe valves. Why be such an asshole when I only asked a legitimate question?
I have worked on a few of these things as well. What you are calling a plug valve is more properly termed a rotary plug valve. It, like a ball valve, is not used in throttling applications. Its primary application is on-off control of flow.
When it comes to throttling applications, globe style valves are used. These are loosely referred to as sliding stem valves as the valve stem operates in an up-down motion. There are three basic types: disc, which are used for on-off control and offer coarse control of flow; plug, which offer positive shutoff yet still provide finer control of flow than the disc and needle, which offer very fine control of flow but are not good for positive shutoff conditions.
The valve in question is a plug style and in the small size, a floating plug is not needed. The tapered plug, machined concentrically with the stem, will seat in the tapered seat of the valve body if reasonable care is taken in its construction. These are model valves for low pressure applications and are used primarily for flow control to control the speed of the model. There is usually a primary shut off valve on the supply line so there is no real concern that the valve be capable of going to full shutoff condition.
kenrinc
03-31-2013, 04:39 PM
Well it turns out there is an issue with, from what I can tell, the die. If I cut an 8-32 thread on a shaft with the die I have and then tap an 8-32 hole, the die cut thread will not enter that hole. If I grab a commercial 8-32 screw it goes fine in the taped hole. Adjusting the adjustable die doesn't make difference in it's ability to size the thread.
The hilarious part of this story is that originally I had a marked 8-32 die, "made in USA" that doesn't cut 8-32 threads. I don't know what it cuts but it's not 8-32. I believe it's 6-32. So I bought another 8-32 die and I just confirmed that it won't cut an 8-32 thread either LOL. You gotta love it.
Ken-
tdmidget
04-01-2013, 01:05 AM
QUOTE=JCHannum;841089I have worked on a few of these things as well. What you are calling a plug valve is more properly termed a rotary plug valve. It, like a ball valve, is not used in throttling applications. Its primary application is on-off control of flow.
Application or not , a plug valve and a globe are not remotely similar'
So I guess you never heard of a gate valve?
My question was how would the concentricity be assured. The OP is being advised to change set ups and all manner of things that may affect the concentricity. I was curious about how to deal with it without complicating the model valve. I am well aquainted with valves and valve types. I merely asked how it would be dealt with. I did not need a bunch of BS from people who do not know one type from another.
JCHannum
04-01-2013, 09:51 AM
Of course I have heard of gate valves. I have also heard of ball valves, pinch valves, butterfly valves, diaphragm valves, you name it. They are not what is being discussed here, so it would be pointless to mention them.
Machining a model valve of this type is no different than machining the full sized version. The machining of the body, bonnet and stem requires care be taken to ensure the areas that are critical to alignment are handled appropriately. To this end, if those areas are machined in one setup each, adequate precision will be attained. I do not see where the OP has been given instructions that would lead to a wildly inaccurate product. With any project of this type, it is important to understand the requirements of the final product and take appropriate care to ensure the desired outcome is achieved.
My procedure would be to turn the stem in a collet or chuck from oversized material. I would turn with the stem toward the tailstock and the plug at the headstock end. The bonnet, I would also turn with the lower end toward the tailstock. I would drill and thread for the stem, turn the OD and single point the threads for attachment to the body.
The body is a bit more of a project due to its being a casting and multiple setups required. I start by cleaning up the casting with a file and squaring the ends and "cheeks". I then drill and tap the inlet and outlet. It takes a bit of fixturing I will not go into, but I now set the body up in the milling vise and drill for the seat per the instructions included with the castings. The body is drilled and tapped to accept the bonnet at this point.
I am not some BS'er as you imply. My career was in the chemical and food processing industries in engineering and maintenance. As far as the project in question, since I have actually made several of these items, I am fully aware of the requirements of the job. PM Research provides the castings in kit form. The valve body castings are provided in a tree of four bodies, the kit also includes handwheel castings, SS stock for the stem and three pieces of brass hex for the bonnet, packing nut and handwheel nut.
This photo is of one valve I made several years ago with a lubricator attached as well as a raw body casting with handwheel casting and barstock as supplied by PM Research. The valve is 1/4" model pipe thread and is 11/16" long. The tee fitting is also from PM Research castings and was machined in a similar manner.
http://i320.photobucket.com/albums/nn351/jchannum/P1100809_zpsa2953ad9.jpg
