View Full Version : Source for spur gears
amateur
04-08-2013, 08:25 PM
I am looking for a source for spur gears for a large mower.
There are three gears in all.First one is a 12DP 49 tooth which drives a pair of 12DP 45 teeth gears.
I have found plain steel unhardened 45 tooth gears,but the 49 tooth is a real odd ball.
Dr Stan
04-08-2013, 09:39 PM
have you tried a supply house that carries Boston Gear?
Ohio Mike
04-08-2013, 09:56 PM
Gear makers are...
Boston
http://www.bostongear.com/
Martin
http://www.martinsprocket.com/
Browning
http://www.emersonindustrial.com/en-US/powertransmissionsolutions/products/gearing/open-gearing/Pages/default.aspx
When I was working on several projects that required gears I went and downloaded all the catalogs so I could compare. During that process I found a surprisingly easily source, Amazon.
