View Full Version : does MT4-to-R8 exist? in canada?
Elninio
05-01-2013, 08:05 AM
http://spares.xyzmachinetools.com/media/STOCKIMG/000DE743.JPG
RussZHC
05-01-2013, 10:51 AM
IIRC, somewhere around this bbs there is a single drawing that shows a bunch of various tapers/sockets and going by a foggy memory, I think one of the points where a taper meets a flat is very, very thin between MT4 and R8, this is assuming you don't want a ton of "stick out" since of course the further "out" you go, the more room the taper has.
I think I've got that drawing somewhere but my own filing system is not that good either so...as an actual piece even just in a catalog listing, let alone in hand, I have not come across one.
Edit: for what its worth, for me, this relates to most previous discussions about what collets fit in a MT 4, how close but not quite for 5C, how tough it can be to find 4C and potential to make adapters to fit other common tapers like R8 etc.
flylo
05-01-2013, 11:14 AM
This work? http://www.ebay.com/itm/R8-TO-4MT-R8-SHANK-DRILL-CHUCK-SLEEVE-ADAPTER-BRIDGEPORT-ARBOR-MORSE-TAPER-MT4-/120939916720?pt=BI_Tool_Work_Holding&hash=item1c2894adb0
Rosco-P
05-01-2013, 12:06 PM
What tooling do intend to use in the MT4 machine? What R8 tooling doesn't require the use of a drawbar to keep it in place?
Arthur.Marks
05-01-2013, 02:46 PM
Rosco-P, et.al.:
A number of Euro machines have a native MT4 spindle which is meant to be used with a drawbar; for example, Deckel (http://www.gizmowizard.com/deckeldapter/deckeldapter_main.htm). As far as I know, there are no commercial sources to buy an R8 adapter at this time. The link above has a drawing if you want to give it a go yourself.
doctor demo
05-01-2013, 02:58 PM
I think that is backwards, He wants it the other way as I read the post.
RussZHC
05-01-2013, 05:09 PM
Arthur.Marks: thanks for that link, may come in handy.
Randy
05-01-2013, 10:31 PM
I made one out of a M4/M3 sleeve by cutting off the tang end and boring to R8. As Russ noted, the tapers almost meet leaving a thin edge, so I added a reinforcing ring.
http://img.photobucket.com/albums/v21/rykrisp/97f2a5b0-3e4d-4283-80b0-c97b8be80928_zpsb1869f69.jpg (http://smg.photobucket.com/user/rykrisp/media/97f2a5b0-3e4d-4283-80b0-c97b8be80928_zpsb1869f69.jpg.html)
iMisspell
05-02-2013, 01:55 AM
I made one out of a M4/M3 sleeve by cutting off the tang end and boring to R8. As Russ noted, the tapers almost meet leaving a thin edge, so I added a reinforcing ring.That's a clever idea.
toyjeep73
05-02-2013, 09:25 AM
I bought one from this guy.
http://www.gizmowizard.com/deckeldapter/deckeldapter_sleeve.htm
Works well. I think he does what Randy suggested above.
