View Full Version : Oil ring groove on a lathe
Prokop
05-13-2013, 09:30 AM
Gentlemen,
Would you mind sharing how you cut an oil ring groove on a lathe? For normal o ring on a shaft I used the parting tool, not a big deal. Than I needed o-ring on the face and I got it done somehow with a HHS bit I kept sharpening to be able to get there - it was next to male thread - but I am sure there are tips and tricks I am missing.
Thanks for your help.
Sun God
05-13-2013, 09:40 AM
O-ring groove on the face of a turned part? You need a trepanning tool.
Prokop
05-13-2013, 10:56 AM
Yes, on the face and sunked in a bit.
lakeside53
05-13-2013, 11:02 AM
Nothing special - If you are grinding your own just make sure your tool has sufficient "outside" relief for the radius of the groove.
