View Full Version : Milling after waterjetting?
beanbag
06-01-2013, 08:28 AM
I'm planning to get a part cut by waterjet oversize, and then I will mill it down to size. Does waterjet leave a layer of embedded abrasive particles that will dull my end mills?
Dr Stan
06-01-2013, 09:22 AM
Not that I'm aware of.
06-01-2013, 09:50 AM
It leaves a layer of rust on steel, and rust is somewhat of an abrasive (rouge).
I don't think much of the entrained abrasive is left, especially if you brush off the rust from the edges first.
dalee100
06-01-2013, 10:59 AM
Hi,
The limited experience I have with machining water jet cuts, (reworking slightly oversized parts), indicates no difficulties with wear. And I haven't ever bothered with cleaning the surface as J Tiers suggests. Though that may be a good idea and certainly won't hurt.
dalee
