View Full Version : Carbide grinder won't run, need wiring help.
Chipster
06-10-2013, 02:18 PM
I bought this carbide grinder at an auction, I plan on using it to sharpen HSS lathe tool bits. When I got back home and plugged it in for a test run it tripped the GFCI when I tried to turn it on. I turned it over and looked inside the base to check the wires, everything looked ok but there are two gray wires with spade connectors coming from the motor that are not connected to anything. The grinder came with a standard three prong house cord and all the wires and connections look like a factory setup. There is no wiring info or diagrams on the grinder. The reversing switch is marked 250v, 10A.
If anyone has a similiar grinder can you look to see what the two wires should be connected to, there are no unused terminals. Maybe something is missing.
The two wires that go thru the side of the base are for the lamp.
Any help getting this grinder running would be greatly appreciated. Thanks
http://pic20.picturetrail.com/VOL1574/7908598/21787213/406871117.jpg
http://pic20.picturetrail.com/VOL1574/7908598/21787213/406871118.jpg
willmac
06-10-2013, 02:55 PM
Start Capacitor? The loose leads touching the base could easily trip the GFCI. If so, you are lucky that it did trip.
Dr Stan
06-10-2013, 03:09 PM
From the paint scheme it looks like a Horror Fright. Go to the HF site and lookup the manual to see wha's missing.
Chipster
06-12-2013, 08:50 AM
I know I got lucky and didn't get any shock therapy, thank goodness for GFCI"s. I seperated the loose wires and made sure they didn't touch anything, but the GFCI still tripped. Any ideas on what size start capacitor I would need. Is there any way to test the motor with a multimeter to check if the internal wiring is ok.
Dr Stan
06-12-2013, 08:55 AM
See my previous post.
For the windings just check to see if they are open (infinite resistance). If they are, just take it to the scrapper.
Chipster
06-12-2013, 10:06 AM
Thanks Dr. Stan, I went to the HF site but couldn't find any info on the grinder. I was hoping someone on this site with a similiar grinder could check and see what capacitor is needed. I will check the wiring.
Shade
06-12-2013, 11:03 AM
I have the same import machine, I am travelling for
work I can check on the caps when I get home. It will
be the weekend.
Chipster
06-12-2013, 11:31 AM
be the weekend.
Thanks that will be a great help, I hope the motor wiring checks out ok.
dian
06-12-2013, 11:56 AM
search this forum, sizing a start cap has been discussed several times. look for posts by jaakko, i believe.
Dr Stan
06-12-2013, 12:03 PM
Try here: http://images.harborfreight.com/manuals/46000-46999/46727.pdf
Part #48 on the list of parts (pg 13) is the capacitor, but it does not list the specs. You could try the 800# but I'd be very surprised if they can tell you the size of the cap.
Chipster
06-12-2013, 03:20 PM
Thanks for that link Stan, manuals always come in handy for finding parts.
Barrington
06-12-2013, 05:08 PM
No point in worrying too much about the capacitor if the problem of the ground leakage can't be sorted out.
Would suggest disconnecting the 4 outer terminals of the the switch and test again for tripping of the GFI. If you're very lucky the leakage might be in the switch body - worth a check anyway.
The lamp wires look a bit suspect - no grommet where they pass through the casting ? Does the insulation there seem o.k.?
(As a matter of interest, how often is a red/black/green mains cable used in the US ? I see the lamp is permanently connected to red, and switched to black - which would imply the red is neutral ??? )
Cheers
demerrill
06-12-2013, 05:34 PM
Here is a link to Grizzly's version of that grinder. I has the capacitor specs listed. But, as noted above, the wiring issue should be addressed before worrying about the starting capacitor. http://cdn0.grizzly.com/manuals/h7762_m.pdf
David Merrill
CCWKen
06-12-2013, 06:07 PM
It looks like some modifications were made to the wiring at the switch. (Note the yellow connectors.) I would check there for miswiring. Did you remove the bottom plate or was it missing when you bought the grinder? The capacitor was mounted on it according to the diagrams in David's link. It shows the cap to be 50mf/300vac. The better hardware stores should have it.
gcude
06-12-2013, 06:34 PM
Looks like the spade connectors went to the capacitor. Missing cap and bottom plate seems to be logical from the diagrams.
Chipster
06-17-2013, 12:24 PM
Did some testing on the wiring and it didn't look good. Pulled the end plate of the motor off and found burnt wiring, this thing is toast.
Thanks to all who replied with their help, but nothing is gonna save this.
