I have an R8 arbor for a face mill, the taper is galled, you know the usual radial galling from slipping in the spindle.
It was given to me, it didn't slip in my machine. There is no sign of damage to the key slot where the pin would be, so it must be who's ever machine it was in when it slipped didn't have a pin, probably what saved it, or why it slipped.
Anyway, I want to clean it up in my T&C grinder, no problem. I can zero it in by setting it up it in my 4 jaw chuck.
What I would like to know is if I grind .005 off the dia. of the taper how much further up in the spindle will the taper seat???
As it is now after I stoned the galling best I could when fully seated in my BP there is about .125 of the taper exposed.
My guess is I can get away with it seating .040 further up with out any issues.
I don't want to have to remove the arbor from the grinder to check it and then try to set it back up again. I would like to do this in one shot and know where I will be when done.
JL....................
