View Full Version : Golf Cart Finished! (Almost)
CCWKen
04-15-2004, 11:20 PM
Don't know if anyone remembers the motor and wiring problems I had on this project but it's complete... Except for batteries. http://bbs.homeshopmachinist.net//frown.gif
After making a new front axle, battery box, console, seats and straightening the front, back, sides and top, I shot a little paint and put new wheels on it. This will be my get the paper and take the garbage cans to the road cart. It's all tested but I still need six 6v golf cart batteries. Any one have/know a CHEAP source?
Before Images:
http://www.photobucket.com/albums/0903/CCWKen/Projects/87Ezgo-B4-1.jpg
http://www.photobucket.com/albums/0903/CCWKen/Projects/87Ezgo-B4-2.jpg
As it looks NOW:
http://www.photobucket.com/albums/0903/CCWKen/Projects/87Ezgo-1.jpg
http://www.photobucket.com/albums/0903/CCWKen/Projects/87Ezgo-2.jpg
http://www.photobucket.com/albums/0903/CCWKen/Projects/87Ezgo-3.jpg
BillH
04-16-2004, 12:02 AM
Needs a gun rack http://bbs.homeshopmachinist.net//smile.gif
Looks good, as far as the batteries, no idea.
I think some old trucks used 6 volt batteries, so they probably still make them.
sandman2234
04-16-2004, 12:08 AM
Probably need to be deep cycle. I think they make a "golf cart duty" battery.
That kind of strain on a regular battery will kill it in a matter of months.
David from jax
laddy
04-16-2004, 08:39 AM
Hey,
Looks great and I don't play golf. I ahve a 53 Ford truck and a 1939 Dodge. I got tired of the little power I had to start them so I put in an 8 volt tractor battery. It starts them up just fine and I didn't hjave to change anything as far as wiring. I do have to use an 8 volt recharger though since I didn't rewire the generator. Just a thought. Good luck Fred
docsteve66
04-16-2004, 09:50 PM
Best price for "golf cart " batteries that I have found is "Sam's club".
I have a motor home, i "figure" I am just renting a battery. Calculate the initial cost, divide by the warranty months and you know the maximum monthly "rental". Golf cart batteries seem to go well past the warranty time- so their "rental" is less. Maintenance is the key to long life- try to charge before they are at the 50 percent charge state, keep water up. An old fashioned hydrometer is a pain to use (needs temperature correction) but once you know how long it takes to re charge after a certain amount of use its easy. keep charge rate low enough that it would take 10 hours to do complete re-charge (C/10 is way the battery shops refer to the charge rate).
And good looking job
PolskiFran
04-16-2004, 10:28 PM
Check in your area if there is a battery manufacturer. They might have a retail outlet at their plant where you might be able to purchace a rebuilt or a second.
I just purchaced 2 batterys last week for the pick up and tractor at the factory. Cost me $18 ea.
Your project looks great,
Frank
