View Full Version : How do you use this tool ?
gt2ride
10-29-2013, 06:13 PM
These two tool came with some metal stuff
I do not know were or how to use them
http://i175.photobucket.com/albums/w147/gt2ride/002-7.jpg (http://s175.photobucket.com/user/gt2ride/media/002-7.jpg.html)
Leon
WhatTheFlux!
10-29-2013, 06:18 PM
Left-handed finklestoddens, genuine Merklewitz from the looks of them. They're used for sub-nubbing tremmie-pipes to wenial-sprockets, as seen on the previous generation of Nofer(tm) trunnions.
loose nut
10-29-2013, 06:22 PM
They are from a set of caliper/divider/compass etc. that has interchangeable tips IE: points for a compass and different size and shape parts as the ones shown for use as inside and outside calipers or hermaphrodite caliper etc. Starret sells these but I don't know if that is the brand of ones you have. Without the rest of the set they will make a good back scratcher.
saltmine
10-29-2013, 07:24 PM
They look like poured Babbitt bearing scrapers. Primarily, they are used to scrape off high spots on bearing surfaces....I think.
JCHannum
They are the caliper legs for a Starrett No. 59 Trammel set.
http://www.transcat.com/catalog/productdetail.aspx?itemnum=59A
boslab
10-29-2013, 07:27 PM
Rekon you nailed it, beam compass type of thing from memory
Mark
boslab
10-29-2013, 07:29 PM
Also nailed but i was reading backwards on an ipad
Mark
madwilliamflint
10-29-2013, 08:49 PM
I still think they're for sub-nubbing tremmie pipes.
Ever tried to do it without a pair?
*shakes head*
loose nut
10-29-2013, 09:45 PM
Yes they are, I was thinking they where from the NO. 85 Caliper set which has almost but not quite the same legs, possibly interchangeable.
JCHannum
10-29-2013, 10:10 PM
The No. 85 calipers use similar, but not interchangeable caliper legs.
http://www.amazon.com/Starrett-85F-Carpenters-Workers-Extension/dp/B000VDXISC/ref=pd_sim_sbs_indust_3
planeman
10-29-2013, 10:47 PM
Strangely enough, I have a Starrett trammel I bought years ago at a surplus place. I never knew there were additional accessories. If you don't want these "caliper" units, I could use them (maybe). Anyway, They should match up with my trammel.
If you want to give them a good home. e-mail me at rufus.carswell@yahoo.com
Planeman
WhatTheFlux!
10-29-2013, 10:52 PM
*shakes head*
No doubt you DO need a pair. Those lacking a pair best not attempt the task.
Spin Doctor
10-29-2013, 10:54 PM
You sir win the golbodygook prize of the day
gt2ride
10-29-2013, 11:13 PM
Here is some of the stuff
http://i175.photobucket.com/albums/w147/gt2ride/029-1.jpg (http://s175.photobucket.com/user/gt2ride/media/029-1.jpg.html)
gt2ride
10-29-2013, 11:17 PM
Thanks Guys
rode2rouen
10-30-2013, 12:25 AM
Don't be silly, those are nose picks.
Rex
Paul Alciatore
10-30-2013, 04:41 AM
You got that half right. But the Starrett photo shows a right and a left hand one. Leon clearly has two left hand ones. So, there not a pair, just two half pairs.
JCHannum
10-30-2013, 08:12 AM
Not only did he get the caliper legs, he also got the trammel heads so he has a set. The wood or metal beam is provided by the user.
He also got a double set (two each size) of adjustable parallels. These are something you do not appreciate until you have them. Overall a good haul.
