View Full Version : Pillow blocks
PT Doc
10-30-2013, 09:22 PM
I'm needing to get some pillow blocks and have seen the standard one with set screws as part of the whole block. Then there are these
http://www.ebay.com/itm/231030445971?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
That have a separate collar. What is the purpose of this separate collar? My application will not have any speed involved. It will allow me to tilt a table top 90degrees.
Thanks for the help.
Bob Fisher
10-30-2013, 09:30 PM
If you would post your location, I might have a pair you can have.. Bob.
sasquatch
10-30-2013, 09:34 PM
The collar is an eccentric that locks/tightens up on the shaft so the shaft turns with the bearing.
Doozer
The collar is just a free bee I guess.
Some bearings use an eccentric locking
collar to fix the bearing to the shaft.
This is not one of those.
I see nothing special.
--Doozer
atomarc
10-30-2013, 09:51 PM
+1 for Doozer. That listing is a lost leader for the silly shaft collars....the guy knows nuttin and he's phishing! Where are you and what size do you need?..I have a box full..brand new and I'm getting too old to use them!
Stuart
PT Doc
10-30-2013, 09:58 PM
I updated my profile. I'm located in Denver.
The collar looked out of place since the eccentric setups look quite different. I am looking for 1" pillow blocks and need about 4 of them.
Thanks for clearing that this is just a useless collar with a setscrew.
epanzella
10-30-2013, 10:40 PM
I've used pillow blocks that have an eccentric collar that can be rotated to jam the shaft in the bearing to insure that the shaft and inner race turn as one.
PT Doc
10-30-2013, 10:45 PM
I have seen those but they are pricier that the standard ones.
Boucher
10-30-2013, 11:05 PM
This place has a good selection and good service. http://www.surpluscenter.com/
10-31-2013, 12:34 AM
VXB Bearing has them for the same money-
http://www.vxb.com/page/bearings/PROD/kit920
If you want US made surplus try Youngs-
http://youngssurplus.com/bearings.htm#Pillow Block
PStechPaul
10-31-2013, 02:50 AM
I looking for pillow blocks a little while ago and I found this company with good prices and free shipping:
http://www.fremontindustrialsupply.com/servlet/the-Bearings-cln-Pillow-block/Categories
Marty Feldman
10-31-2013, 10:43 AM
While this ad contains the information that this is an "import product", meaning China-made most likely, I don't like the fact that the company name begins with "USA" in big red caps. Not saying that China-made automatically means bad, just don't like what looks to me like an attempt at deception.
