Seems like if you forget and leave gas in the power lawn equipment, chain saw and other gas engines they don't want to run well after a year or so. There must be some magic stuff to add into the gas tank to somehow clean the system, huh?
I've seen it so many times, the engine is running fine, put it away with gas in the tank and after a length of time it runs like crap. In my neighborhood in the spring you see any number of perfectly good mowers out on the curb because the owner couldn't get them to run again.
My chain saw just did this. Running fine when I loaned it out in the early spring, needed it the other day and I had to run a bunch of new gas through it to make it start and run worth a damn.
