View Full Version : Quick VFD wiring question
ritzblitz
12-23-2013, 09:24 PM
Hi guys!
This is my first post here. Looks like a good place.
After a failed attempt at wiring a phase a matic to my new Clausing 5914, I would like to try to wire up a VFD (Hitachi WJ200 2HP). All I need to do is provide power to the machine, the VFD will remain at one frequency.
My quick question is this- Is it really that simple to wire these up? It is single phase, so two hots from my 220V IN, and 3 hots out to the machine?
Which color wire goes where on the VFD output?
I read that VFD needs to be wired in between the motor and the switch? Is this correct? Can I just plug in the existing power wire to the VFD and not mess with anything on the machine?
The wiring goes from the wall to a box to the motor and drum switch.
Thanks for your help, I don't want to fry anything here. Is frying the electronics a likely scenario if I screw up the wiring? Or are there built in failsafes?
-Alex
lakeside53
12-23-2013, 09:48 PM
The wj200 is pretty tough, but you can easily fry it if you do something dumb. And even though it's possible with some vfd to switch the outputs between the motor and VFD, Hitachi specifically says not to.
I recently converted a 6913. The original drum switch (same as the 5914) was repurposed to provide LOW VOLTAGE inputs to the WJ200 for Forward, Stop and Reverse. In my case the lathe had a Clutch and Brake, so the vfd was programmed to not use programmed deceleration as it runs independent of the drive train. Relatively easy with a little experience, but you do need to be able to read the manual and set the vfd registers to other than the factory defaults.
If you are really as electrically challenged as you suggest in your other (PM) post, you might want to seek some local assistance; there more to wiring a vfd (or any machine) safely than can be assumed from base knowledge of zero. The manual covers which wire goes where, but yes, in the simplest configuration it's 2 wires (240v) plus ground in, and 3 wires plus ground out.
Does your machine have a both the brake and clutch?
BTW.. the Phasematic static converter will work if you wire it correctly.
Where are you from? Please fill in your location (profile0. Electrical advise is meaningless unless we know which county you are in.
ritzblitz
12-23-2013, 09:56 PM
Hey Lakeside,
Thanks for the reply. Yes I am fairly electrically challenged. I wish I wasnt, it has just never clicked for me.
However, I am not stupid and I can follow instructions well.
My machine has a brake and a clutch yes.
So are you saying that I can just wire it up and go? Or do I need to wire it into the drum switch with a low voltage (how do I change voltage?). Do the locations of the motor wires on the VFD matter? Can I just randomly plug them into the VFD? Like I said, I am purely looking to supply 3 phase power to the lathe. The variable drive is in good condition, I just need to get it up and running.
The milling machine will be the bigger challenge.
Edit:
Whoops, forgot my location.
I'd like, for my own sanity, to get the static converter working. It would be an accomplishment. I'm gonna hook it back up to the milling machine (where it lived before) and assure that it functions. Then maybe I can figure out what's going on with the lathe side.
Can you offer any advice on the static converter? I tried different positions of the wires but no dice (probably not the best idea to go switching outputs around?)
jlevie
12-23-2013, 10:07 PM
If the static phase converter was a challenge, I'd say that a VFD is way beyond your skills. And if you want to be able to reverse the load w/o risking the VFD the drum switch will require rewiring so that it tells the VFD to run the motor in the selected direction as well as starting and stopping the motor. The VFD then is connected directly to power and to the motor.
lakeside53
12-23-2013, 10:08 PM
You need to remove the power wring from the drum switch and connect the vfd directly to the motor. The drum switch will be then need be connected with just three wires plus signal ground directly the vfd programmable Low Voltage inputs. The "low voltage" is provided by the vfd.
Poor choice, but... the Static converter will work if you wire it correctly.
Doozer
12-23-2013, 10:16 PM
Did you look at the instruction book?
This kind of thing is usually spelled out pertty well.
If it was not clear, Wire the VFD directly to the motor with no switch.
The rest you can't mess up too badly.
--Doozer
ritzblitz
12-23-2013, 11:21 PM
Thanks guys.
I did look at the instruction book. The CD was much better. I'm going to read it more carefully tomorrow.
I'm going to be taking the rewire drum switch route.
Static is only a challenge because I am uncertain of why it is not working. I have wired it up the way it said in the instructions I found.
I appreciate the help, thanks for helping a noob
Side question, but I'm trying to learn.. Why does the voltage across the drum switch drop to zero when I put it in forward or reverse? On two of the poles it is 120v in the off position.
MetalMunger
12-23-2013, 11:38 PM
Blitz,
I am afraid you are in the deep end of the pool way, way over your head!
The voltage across an open switch drops to zero when you close the switch because you cannot measure potential across a dead short.
Find someone in your area that knows what a VFD is and how it operates pay them in money or beer and save yourself the cost of a new VFD or a trip in the meat wagon.
Sorry to be blunt.
PStechPaul
12-24-2013, 12:39 AM
Yes, if you want to learn about electronics, the place to start is NOT an industrial VFD and induction motors on mains power. I would suggest one of the many experimenter kits you can get, where you can start with safe low voltage projects until you become more knowledgeable and confident in your abilities. And hopefully you will make many mistakes (as I did while learning) on circuits where the damage and risk of injury are minimal. Even low voltages can be dangerous. If you wire an electrolytic capacitor backwards, or even try to put too much current through it, it will overheat and explode with enough force to put out an eye or cause painful burns. Whatever you do, at least wear safety glasses. And other common sense rules are to take off any conductive items like rings and watches with metal bands, and keep one hand in a pocket when poking around with or without a meter.
One basic concept that took me awhile to "get" was that voltage is always between two points, and current is always through a conductor or component. There are also no perfect conductors or insulators, so there will always be some voltage across what appears to be a "dead short", and there will be some current flow through an insulator (and even air or vacuum). Also, any instrument you use to take a measurement will have some effect on the circuit, and there is always some error in any measurement.
Something else to bear in mind is that there can be voltage present in a circuit or component which is not connected to AC or batteries, because capacitance may be present. A large motor or transformer or even a length of coaxial cable can retain a high voltage for a long time, and it can cause a very high current surge which may result in an arc flash or shock. And anything with inductance (such as a motor, transformer, or electromagnet) can hold a lot of stored energy, and even if you are using a 1.5 volt battery, it can generate hundreds of volts if you break the circuit (as I found out when I was a kid).
Good luck, and be safe!
Forrest Addy
12-24-2013, 04:56 AM
Can't delete response. Won't return from "Save". System OK?
Oops! It's OK now.
RitzBlitz. I know a little about drives etc and a few others who posted here are more knowledgeable than I. A few post are not to be counted on but which is which?
You, as an electrical noob, haven't the means to distinguisih good technical advice from bad. Here's good non-technical advice: find a local motor and drives guy with actual credentials and either pay he fee or bribe him with pizza or a home cooked dinner to save your bacon. Cheap compared to screwing up your drive or spending days or weeks in impotent frustration.
There's still lots of industry in Allentown. Look in the Yellow Pages under "motors and controls" The Yellow Pages are still the quickest way to track down local resources.
Hard to beat having an expert handy to direct your moves.
ritzblitz
12-24-2013, 07:56 AM
Again, thanks for the replies.
I'm glad you all take the time to respond to someone with zero knowledge and not bash.
I think I am beginning to wrap my head around the basic circuitry to control the lathe with the drum switch through the VFD.
I may be in the deep end of the pool but I'm not drowing (yet).
As I am wiring the VFD in nearly it's most basic setup, I will continue to pursue this and get help if I get stuck.
jep24601
12-24-2013, 09:29 AM
You could throw the drum switch away and just use simple pushbuttons - that's what I did.
ritzblitz
12-24-2013, 10:17 AM
Yeah I could do that. However, I would like to retain the original functionality of the fwd/rev switch on the machine.
ritzblitz
12-24-2013, 11:00 AM
Ok, in my other thread on PM, I was asking about this phasamatic static converter I've been trying to get working.
I rewired it to my milling machine, where it had worked before when I inspected the machine under power. Now at my shop, no dice. No humming, no red light, nothing. Same with the lathe.
Testing with my voltmeter, I get 120V at each lead in the conduit box (A,B,C). This is puzzling to me. Why doesnt anything happen??
Not sure if this matters, but I have a 15A breaker supplying the 220v.
jep24601
12-24-2013, 11:56 AM
Sure complicates a VFD hookup but if you can figure out how to do that all the more power to you. The lever forward/off/reverse switch on my LeBlond regal was sure a pretty switch but there is something to be said for simple wiring and with a VFD it can be very simple.
ritzblitz
12-24-2013, 01:20 PM
Let the flaming begin...
I hereby declare myself an idiot.
The 30A breaker that I installed in the main panel was at the bottom of the panel where only one pole contacted. I just noticed this.
Now the static converter works as it should.
Question:
I've been told static converter is not ideal for lathes. Can I get by for now running the clausing off of this converter? What are the downsides? I understand I cant utilize the full motor HP through the converter, correct?
I want to use the VFD I got for my milling machine, and just supply 3ph power to the lathe as simply as possible, nothing fancy.
THANKS
lakeside53
12-24-2013, 01:22 PM
This is a tiny part of the basic understanding of electricity that you need... ;)
If you measure a 240v "hot" from to ground or neutral, it will show 120v (assuming you ground is correctly bonded to neutral at the panel or transformer). If you measure from hot to hot, it will be 240v. if you don't get 240 hot-to hot, dig deeper. Be careful with parasitic voltage - if there is a device installed you often can measure a voltage but it may not be able to source any current. A light bulb can be a good indicator in such cases.
A static phase converter simply passes both "hots" through to the destination motor, and for the start-up time creates a third leg out of phase with the original. One the motor is started, the third leg drops out.
lakeside53
12-24-2013, 01:28 PM
Question:
THANKS
The principle downside is that you are limited to about 50% power (some will say 66% but that is not correct). The real problem is that YOU have to limit the power to 50% or the motor will overheat. The motor is quite happy to provide as much power as you demand of it until the magic smoke is let out. Ideally, the motor should be provided with a current sensing motor starter to protect it, but on your type of lathe this is rarely installed
You may think 2hp de-rated by 50% for the static converter is a lot.. but the reeves variable speed drive is horribly inefficient - you will loose 30-40% of your input power in the drive.
The second reason... because the motor is running on 2 out of three windings, it will not run smoothly and this can translate into surface finish issues.
lakeside53
12-24-2013, 01:33 PM
It's dead simple. With a multimeter : find a switch common then look for which contact closes for forward and which closes for reverse. There are several to choose from.
Personally.. I think push buttons and a fwd/rev switch are better also (more-so on a mill), but some choose the drum switch. In the case of the Clausing, the drum switch location and actuator make it very easy.
ritzblitz
12-24-2013, 04:07 PM
Thanks guys.
So, how do I limit the power to 50% on my machine?
Since I got it running, I took some test cuts.
New question- It will randomly shut off (not motor but feed/spindle). It seems like the clutch is screwy, but could this have anything to do with the static converter? This wasnt happening when I tested it out on 3 phase. It would shut off when I sped the spindle up, but then when I tried again it wouldnt happen.
I need to check the manual and fill up whatever reservoirs are present for the clutch.
lakeside53
12-24-2013, 04:43 PM
The clutch is mechanical (interlocked with the brake and at the right end of the counter shaft) - the variable drive is hydraulic. Nothing to do with your static converter. There are adjustments for both the brake and the clutch, but if your pads are worn or oil soaked, time for a rebuild. Welcome to old Clausings... Here's s few pictures from a conversion I did - removed the entire hydraulic assembly but retained the clutch and brake. I hid the VFD potentiometer inside the old hydraulic speed control. Some of the pictures may be of value to you.
http://s238.photobucket.com/user/lakeside53/library/Clausing%20conversion?sort=4&page=1
Like any electric motor, you have to limit power by your actions - i.e., how much material you cut per unit time. There are charts and formulas available, but don't get too concerned about the science; keep the duty cycle low and don't overload the motor. If you "really" need to know you can watch current or motor rpm. Motor rpm will decrease with increasing load. The name plate rpm is 100% load. At light loads it will be higher - 50% is somewhere in the middle.
If programmed correctly a VFD will limit power within the motor design limits - an often overlooked feature.
