View Full Version : Demagnetizer
loose nut
12-30-2013, 08:09 PM
Does any one have any experience with using a demagnetizer on a digital caliper or any other digital measuring tool. Is it safe to use or will it scramble the electronics.
jhe.1973
12-30-2013, 08:23 PM
I doubt that it would scramble the electronics.
I would just close the caliper & demagnetize the metal beam. It should take care of all the metal that way.
KiddZimaHater
12-30-2013, 10:25 PM
I've done it several times. It won't hurt your calipers.
Of course, I did it while they were turned 'OFF'.
jlevie
12-30-2013, 10:31 PM
Probably safer to take the battery out first.
loose nut
12-31-2013, 09:21 AM
Thanks for the replies.
radkins
12-31-2013, 02:34 PM
I had a thread on this just recently, I had wondered the same thing and it occurred to me to just try it on my cheapo HF calipers first since they cost so little nothing would be lost. I plugged in my DE-magnatizer, pulled them across it a couple of times then checked them out, no harm at all done to them. So now I have even done it to my Mitutoyo and Starrett and have done so a bunch of times with the HF cheapies with zero problems. Using the HF cheapos I have run them across with them on and off both with the jaws open and with them closed, apparently it's harmless no matter what.
