View Full Version : Anyone fluent in Mach3 problem solving????
Davek0974
01-29-2014, 10:38 AM
Hi all, I'm nearly ready to test my 1st CNC table now so I thought I'd get the breakout board hooked up to mach3 and get the e-stop, limit and spindle/torch signals working and debugged.
The inputs are fine and perform as needed but I have no output to trigger the relay on the breakout board.
If I reboot the PC, the relay energises and stays on so I'm guessing the LPT port, cable and board/relay are all good.
As soon as I load mach3, the relay drops out and I cannot get it to re-energise again.
The board leaflet says spindle relay is on pin 9 and I have mach3 set for Output#1 on pin 9 and spindle fwd/rev to pin 9
Any ideas as I'm stuck right now and can't progress.
Thanks
Davek0974
01-29-2014, 10:54 AM
Just tried a fresh install on another PC, different make but exactly the same behaviour.
Knires
01-29-2014, 11:27 AM
I would start by only having one output per pin. Don't have 2 outputs on pin 9. You can change them between active high and active low to see if the relays respond as well.
Next, it is best practice to have your e-stop remove power to your spindle or what ever you are controlling as well as the e-stop pin in Mach3. As you are seeing those pin states can change on a whim during the computers start up and shut down. Always trip your e-stop before closing Mach3 and shutting down and always start Mach3 before releasing your e-stop.
Davek0974
01-29-2014, 01:04 PM
Thanks
I'll try removing the CCW output to pin 9 and try that.
Re the relays, yes, it will need some safety features adding but that's pretty simple stuff.
Davek0974
01-30-2014, 03:17 AM
FIXED!
There was a little post i found on a google search.
There is a tick box - "Max CL Mode Enabled", this was checked, unchecking solved the issue :)
Happy days, thanks for the help.
SGW
01-30-2014, 08:04 AM
Do you know about http://www.machsupport.com/forum/index.php
Davek0974
01-30-2014, 01:03 PM
Hi
Yes, thanks, I'm already on there :)
ironmonger
01-30-2014, 01:38 PM
Thanks
Did you try to remove the CCW output? I was curious whether or not that was part of the problem.
paul
MaxHeadRoom
01-30-2014, 02:57 PM
This also shows why all power devices energized by Mach be in the hardwired E-stop state at power up, and the E-stop circuit only be enabled when mach has loaded.
Otherwise things like spindles etc can start up at undesired times.
Max.
Davek0974
01-30-2014, 03:30 PM
paul
Yes and it makes no difference, all it does is divert both cw and CCW signals to the same pin
Max.
It's a very good point, and will be put into practice too.
Is there a way of finding out when mach3 has loaded?
