Looking at an old "FrankenMill"
  • astroracer
    • Jan 2005
    • 112
    A co-worker is selling this old "mill". I'll check it out of course but he says it runs fine and is fairly clean. He's asking 600
    The base looks to be an old belt driven horizontal mill and it has been retrofit with a BP "M" head. He said he has some tooling and the big milling vise will go with it
    He is going to pull the numbers off the head unit tonight. Do any of you think one collet system is better then another? I know an R-8 would be great but I doubt that is what it is.
    Thanks for any thought or suggestions.
    Mark
  • portlandRon
    • Feb 2004
    • 353
    #2
    Bridgeport "M" heads could be had with a #2 Morse taper or with a B&S #7 taper.
    Both have limited holding size and if you look on ebay you will be able to get an idea of availability and cost.
    • Doozer
      Junior Member
      • Jan 2005
      • 10595
      #3
      I like it, but it depends on your use and skill level.
      M-heads chatter when used with a boring head,
      so forget using one with this mill.
      Fly cutters and shell cutters limited to 1-1/4".
      -Doozer
      DZER
      • boslab
        • Dec 2007
        • 8867
        #4
        I was given a Bridgeport head with a horizontal mill i bought, the overarm slips out and the round arm if you will fits in, it has no motor at the moment so i have never used it, also it lacks the "knuckle" joint so it looks reasonably rigid, have never used one, was surprised how small the drive belt is, the stepped pulleys are really tight together, looks like a handy drill or for very light milling, i seem to spend more time with plastics these days, ideal for that i suppose
        Mark
        • madwilliamflint
          • Sep 2010
          • 557
          #5
          I might not know nuthin about nuthin. But for 600, that's a steal if it turns on.
          Proud machining permanoob since September 2010
          • Peter S
            • May 2002
            • 1546
            #6
            The mill looks to have very limited cross travel (Y-axis), although the photo may be deceiving me.
            Hold out for a real turret mill IMO.
            • krutch
              • Jan 2010
              • 735
              #7
              For that price ya can't go wrong. If this is your first mill, get ready to want one larger. But still a good first machine. My brother would want that one for the little mill work he does. Mostly slotting holes and such.
              If nothing else a good trading machine. Looks clean and not abused.
              Krutch
              Mentally confused and prone to wandering!
              • Rex
                • Oct 2004
                • 1058
                #8
                Hopefully you have it home already
                • rklopp
                  • Feb 2003
                  • 580
                  #9
                  -Doozer
                  Bull. I used to use a 2" boring head with my M-head "Clausport" a lot, and could avoid chatter if I set and fed the tool properly. Same as using a boring head in any mill. The most limber part is the tool, not the M-head spindle.
                  • astroracer
                    • Jan 2005
                    • 112
                    #10
                    Hey guys, I am still working on getting this thing home. Should happen in the next few days. The two biggest issues were moving the thing and having a way to get it 45 miles from his shop to mine. Both issues have been resolved so now I am just trying to hook up with a friend who has a big lowboy car trailer.
                    I have been pretty busy this summer with other projects and the PO wasn't in a big yank to move it so it hasn't been a big deal but I have some work I can do on it now and need to get it set up.
                    Does anyone have any B&S #7 taper tooling they could/want/need to part with? Just looking for basic end mill holders and what not at the moment.
                    Thanks
                    Mark
                    • Old Hat
                      • Mar 2014
                      • 1916
                      #12
                      Excellant! So glad you bought it. Be carefull with moving it!
                      Remember to that some help isn't help. I have two good friends
                      that I take great pains to avoid when moving machinery.
                      Lastly it's got real potencial and you can get past some of the limitations
                      mentioned above with a few tips. Keep your eyes open for a DRO for it.
                      Expand it's foot~print one way or another.
                      Lag-bolt it to a heavy pallet (skid) or similar method.
                      I'd like to see the right hand side O' the table and the knee a little closer!
                      • astroracer
                        • Jan 2005
                        • 112
                        #13
                        Thanks guys! Yea I have eBay tagged for this stuff so I am keeping an eye out there.
                        To move this thing I bought a pallet jack at a yard sale for $95... It lifts the mill very easily and rolls it around just fine. The jack is wider then the mill base so there is no overhang. I'll get pics while moving it. I am hoping today is the day. A friend has a very low twin axle car trailer with a tilt bed so loading and unloading shouldn't be to bad.
                        Mark
                        • Old Hat
                          • Mar 2014
                          • 1916
                          #14
                          A separate line (rope) attached low on a machine and brought (taken) also low
                          to some secure object and taken one wrap around said object and the slack
                          kept out by an independant helper is one of the tennants of safe machinery moving.
                          This line is used to "brake" any unintended movement
                          should the men moving a machine loose controll of it.
                          It's called a tag-line by some, althO' tag-line to me is a line that one uses
                          to guide or rotationally restrain a load that is be-ing craned overhead.
                          • J Tiers
                            • Jan 2004
                            • 44377
                            #15
                            Mill looks perfectly usable....
                            Could indeed have limited cross travel, because as a horizontal, it wouldn't NEED a lot.... you put the cutter where the cut is.... So move the ram to where the cut is..... it has enough table that you should in general be able to set the long cuts along the table.
                            But it's not much worse for that, if it's even true, and $600 for a working vertical mill is not bad at all... think of what crap you would get from jet or Griz or HF for that.
                            No matter what the machine, there will ALWAYS be someone who will "kindly" warn you about the problems it has.... so the best advice is to see if YOU like the machine... and buy it if so. Looks like you did, good on you for that.
                            Originally posted by Old Hat View Post
                            [B
                            LOL!
                            Yeah..... two types of folks I avoid....
                            1) the "let's git it done!" guys who rush, do things that shouldn't be done just to save a few seconds, and are always where you don't think they are.... so you have to watch them like a hawk for their own good.
                            2) the opposite ones.... "I think it would be a lot better if we used this other plan" (that requires things we don't have and can't get until next week), they are never in there helping, but have a lot to say.
