I am fitting stepper motors to my lathe and needed to drill and tap a hole very near the edge of the cross slide casting. The hole was fine but the tap broke through the edge of the hole. The bolt threads in fine but clearly it is not as strong as I would like. Is it worth building up the edge of the casting with DevCon? If so, can I clean the casting, oil the bolt and thread it in the hole and then build up (slather it on) the side of the casting with Devcon and still expect the bolt to unthread? I cannot go over size and I won't be able to re-drill and tap the hole again. Any other suggestions? Are any of the Devcon (steel, aluminum etc.) better or stronger than any other or is it just cosmetic?
