View Full Version : Control board for CNC Laser Mach 3 Cat 5 Ethernet
wmgeorge
03-06-2014, 02:13 PM
http://www.automationtechnologiesinc.com/products-page/breakout-boards/smoothstepper-ethernet-motion-control-board-for-mach-3
Anyone use one of these with Mach3 - Ethernet vs USB as I was considering.
lakeside53
03-06-2014, 03:10 PM
I've used it and love it. You can get a bit lost in the initial network setup, but once it's up it works perfectly. Warp 9 support forum make it all easy. I can even run it from a laptop - try that with a typical laptop parallel port. In fact, it removes most the windows and hardware related issues.
I chose it over the USB version - that one has/had issues...
macona
03-06-2014, 07:20 PM
I would not use one for a laser cutter. Mach3 is less than optimal for that. Cant do raster engraving worth a damn.
I would actually look at one of the chinese controls from Lightobject.
wmgeorge
03-07-2014, 09:15 AM
Yes I placed my initial order from Lightobject yesterday and Marco suggested the same. Mach 3 is great for machine control, but not for laser engravers. That guy is great, I have watched his online responses to customers and he really truly cares.
Did you use the Misumi extrusions when you built yours?
macona
03-07-2014, 11:00 AM
No, I built mine on top of an old lab robot. http://bbs.homeshopmachinist.net/threads/42918-Project-Laser-Cutter
