View Full Version : Which DRO?
abenevega
05-11-2004, 02:32 PM
I'm looking for a DRO for my mill. I used them, but never owned one. There are alot out there. How does everybody rate the following DRO's and what are the +/-'s between the glass scalesand the other types. Here are the brands to consider:
Acu-Rite, Newall, Fagor, Sargon, Anilam, Sony, Heidenhain, and Mitutoyo
mayfieldtm
05-11-2004, 03:15 PM
I purchased a Sargon System for my Mill a couple of years back from www.candomachinery.com (http://www.candomachinery.com) (no affiliation).
I could not find better pricing.
I hoped I might like a DRO, however, as it turns out, I really liked it.
I mean I really, really loved it.
DRO's simplify the overall machining process and it has lowered my error rate.
I can easily position my table to within 0.0002", where before, I could no way read my little dials to that.
I've since converted to CNC and don't use it that much. Will probably transfer it to the Lathe.
One thought to save some $$$ would be to purchase the scales only, (get TTL Quadrature output), and use a computer to display the Position using the Parallel Port.
Use some software like Mach1 from ArtSoft or some freeware that can be found on the Web.
So... After you've read all the pros and cons, Call Mike at CanDo. He was very knowledgeable and friendly and mixed and matched scales to best fit my machine.
Tom M.
SGW
05-11-2004, 05:04 PM
I expect any of those brands would make you happy. It turns out that Acu-Rite and Anilam are now, I think, the same company. The different brand labels still have different features though, so you can't call them "the same thing."
When considering what to get, don't confuse "accuracy" and "resolution." They aren't the same thing at all. Resolution is only what gets displayed. The display might read to 0.0001", but in reality the point you're at could be a couple thousandths in error relative to a reference point. Some manufacturers are better at giving you ALL the specs than others...and regardless of manufacturer, the obfuscation seems to increase as the precision goes down.
I think Acu-Rite has the most informative web site. They give good specs. (Not to say that the others' equipment may not be equally good, but I don't think they present the information as well as Acu-Rite...at least not on their web sites.
Regarding precision, I think glass scales are at the top of the heap. Their problem is fragility, although if mounted properly with adequate protection from damage, I don't think it's much of an issue.
I'm sure others have different opinions....
Astro
05-11-2004, 05:08 PM
I have a Newall C-80 on my mill with the knee as the Z axis. On my lathe I have a Newall DP-8. Mike at CanDo had the best price.
Robert
jfsmith
05-11-2004, 05:29 PM
I have an Acu-Rite on my mill and my lathe, I am happy with both of them.
Jerry
kenc
05-12-2004, 04:33 PM
Sargon prospector - the bolt hole feature is *very* nice!
Ken
