I've got a line on a Hardinge DV59 that won't run. Owner says that when he puts an ammeter on it, one phase shows 3 amps draw (which I believe is the stated rating) and the other draws 5 amps. Without seeing it, does that sound like something that might be repaired, or should I plan to just find another motor? Anything special about those Hardinge motors (I believe it's from the late '50's) or will any decent motor work?
Unfortunately, I don't have 3 Phase in my shop, so I'm limited in my ability to really test it other than static tests with a multimeter.
I'm going to look into renting or perhaps buying an inexpensive 3 phase converter. (Naturally, I sold the one I had since I didn't think I'd ever need one)
He's only asking a couple hundred bucks for her, so it seems like a low-risk proposition even if I have to replace the motor.
